Followed instructions - All 4 apps are in ST IDE and published and webCoRE set to True. Not showing up in ST Classic - My Apps
Installed webCoRE - SmartApp is not there
          jkp
      - you are logging into IDE at https://account.smartthings.com?
 - you are using the SmartThings Classic app?
 - you are logging in with the master account and not a shared account?
 - you only have one location/one hub?
 - you published all 4 Smartapps in ide?
          anon54870072
      - Yes, logged into IDE
 - Yes, Classic app
 - Yes, logged in as master
 - Now have two locations. A new one just appeared but no hub is on it. The original one is where everything is.
 - Yes, and followed the instructions
I installed the Konnected smart app recently and that went fine and is working but can’t get webCoRE to app to show up on the ST mobile app. And checked with an iphone and android. Not there
          anon54870072
      Problem solved. Was a password issue. When Samsung required me to create a Samsung account I kept the same password and could not sign in to ST any more so I signed in with my Samsung account. I changed my password on the ST Classic app then used the same passsword to sign into ST IDE. That fixed it and now have WebCoRE installed and on the phone. Now to get started!!
