I moved all of my pistons from ST to HE a few months ago. I just went to make some adjustments to a piston and cannot find the Stays On command in the task drop-down. I may not be remembering things correctly, but it seems like that used to be an option. I completely wiped out my ST account so I can’t check. Can someone who still has access to WC on ST take a look? I’m curious as to whether there may be differences between WC on ST and WC on HE that might have affected my pistons as I imported them to HE. TIA.
Is Stays On gone?
markplewis
Thanks for checking. Here’s what I have available on HE:
I want a push notification if a light stays on for more than 10 minutes. I chose is now and stays and it’s working. I do wonder how my old pistons translated to the new Hubitat WC code in instances where the same command weren’t available, though.
E_Sch
The string you see is updated in HE, but this is just for the IDE, the underlying command in the pseudo code is the same (hence things move over fine).
