LIFX Effect Help Needed
Is there a way to use the default effects for LIFX bulbs such as ‘Flicker’?
I’ve use the outdoor light manager piston from @ady624 and got it working with the exception of my halloween mode. I would like to somehow set the lights to have the default LIFX ‘Flicker’ effect.
No options that I can see for ‘Flicker’
N/A
Can’t do it straight away, have tried. But jdogg submitted this piston and works great. I have it being run on each of my individually. If you read through the post I have a video in there of the results.
Ok great, Thanks for the solution!
