LIFX lights take too long to turn on (10 bulbs take 19 seconds)
I want all of the LIFX bulbs to turn on at the same time
I understand webCoRE does things in sequence, except ASYNC commands which should apparently only be used in the case of a WAIT command. But, there’s got to be a way to turn on 10 LIFX (or any other) bulbs faster than 19 seconds (I know they’re on the Cloud vs. local). Has anyone else figured out a better/faster way?
|+0ms|╔Received event [Home].test = 1573931746522 with a delay of 0ms|
|+134ms|║RunTime Analysis CS > 20ms > PS > 62ms > PE > 52ms > CE|
|+136ms|║Runtime (37507 bytes) successfully initialized in 62ms (v0.3.10a.20190223) (135ms)|
|+137ms|║╔Execution stage started|
|+142ms|║║Cancelling statement #1’s schedules…|
|+3333ms|║║Executed physical command [Bunkbed].on() (3182ms)|
|+3335ms|║║Executed [Bunkbed].on (3184ms)|
|+5601ms|║║Executed physical command [Cabinet].on() (2263ms)|
|+5603ms|║║Executed [Cabinet].on (2265ms)|
|+6906ms|║║Executed physical command [Firepit].on() (1299ms)|
|+6907ms|║║Executed [Firepit].on (1301ms)|
|+8854ms|║║Executed physical command [Flood].on() (1944ms)|
|+8856ms|║║Executed [Flood].on (1946ms)|
|+10771ms|║║Executed physical command [Left].on() (1911ms)|
|+10773ms|║║Executed [Left].on (1914ms)|
|+13649ms|║║Executed physical command [Middle].on() (2873ms)|
|+13650ms|║║Executed [Middle].on (2875ms)|
|+15117ms|║║Executed physical command [Nightstand].on() (1463ms)|
|+15119ms|║║Executed [Nightstand].on (1465ms)|
|+16140ms|║║Executed physical command [Porch].on() (1018ms)|
|+16141ms|║║Executed [Porch].on (1020ms)|
|+17843ms|║║Executed physical command [Right].on() (1698ms)|
|+17844ms|║║Executed [Right].on (1700ms)|
|+19136ms|║║Executed physical command [Table].on() (1288ms)|
|+19138ms|║║Executed [Table].on (1290ms)|
|+19142ms|║╚Execution stage complete. (19005ms)|
|+19144ms|╚Event processed successfully (19143ms)|
