Tile piston strangely turning on random light when others are dimmed to 0%
To be able to dim one light to 0% and not have other lights turned off or on
The tile piston monitors status of hue lights, if one is dimmed to 0% via ST app, one or more of the others get turned off or on. If I pause the tile piston, the behaviour stops and also the logs in ST app states the off / on commands are coming from the Tiles Piston.
In the example below, I dimmed the spare room light to 0% from within the ST app and then a moment after the spare room light turns off, the kitchen worktop light turned off.
Below is a snapshot of the piston.
Piston log below:
|+2ms|╔Received event [Spare room light].switch = turningOff with a delay of 153ms|
|+157ms|║RunTime Analysis CS > 24ms > PS > 64ms > PE > 68ms > CE|
|+160ms|║Runtime (58213 bytes) successfully initialized in 64ms (v0.3.109.20181207) (158ms)|
|+161ms|║╔Execution stage started|
|+173ms|║║Cancelling statement #91's schedules...|
|+186ms|║║Calculating (string) turningoff == (string) on >> (boolean) false|
|+193ms|║║Executed virtual command setVariable (4ms)|
|+213ms|║║Calculating (integer) 3 + (integer) 1 >> (integer) 4|
|+219ms|║║Executed virtual command setVariable (3ms)|
|+227ms|║║Executed virtual command setVariable (4ms)|
|+238ms|║║Calculating (integer) 4 - (integer) 1 >> (integer) 3|
|+245ms|║║Executed virtual command setVariable (3ms)|
|+259ms|║║Calculating (integer) 4 - (integer) 1 >> (integer) 3|
|+265ms|║║Executed virtual command setVariable (4ms)|
|+273ms|║║Executed virtual command setVariable (5ms)|
|+309ms|║║Calculating (string) 1 + (string) % >> (string) 1%|
|+320ms|║║Calculating (string) 1% + (string) 4425 >> (string) 1% 4425|
|+326ms|║║Calculating (string) 1% 4425 + (string) K >> (string) 1% 4425K|
|+336ms|║║Calculating (string) 1 + (string) % >> (string) 1%|
|+344ms|║║Calculating (integer) 4425 > (integer) 0 >> (boolean) true|
|+368ms|║║Calculating (boolean) true == (boolean) true >> (boolean) true|
|+382ms|║║Calculating (boolean) true == (boolean) true >> (boolean) true|
|+390ms|║║Calculating (boolean) false == (boolean) true >> (boolean) false|
|+400ms|║║Calculating (enum) turningOff == (enum) on >> (boolean) false|
|+413ms|║║Executed virtual command setTile (2ms)|
|+417ms|║║Cancelling statement #226's schedules...|
|+424ms|║║Executed virtual command setVariable (4ms)|
|+441ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+448ms|║║Cancelling statement #229's schedules...|
|+453ms|║║Executed virtual command clearTile (1ms)|
|+469ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+475ms|║║Cancelling statement #229's schedules...|
|+480ms|║║Executed virtual command clearTile (1ms)|
|+496ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+503ms|║║Cancelling statement #229's schedules...|
|+508ms|║║Executed virtual command clearTile (1ms)|
|+525ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+531ms|║║Cancelling statement #229's schedules...|
|+536ms|║║Executed virtual command clearTile (1ms)|
|+553ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+559ms|║║Cancelling statement #229's schedules...|
|+564ms|║║Executed virtual command clearTile (1ms)|
|+580ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+587ms|║║Cancelling statement #229's schedules...|
|+592ms|║║Executed virtual command clearTile (0ms)|
|+608ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+615ms|║║Cancelling statement #229's schedules...|
|+620ms|║║Executed virtual command clearTile (0ms)|
|+637ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+643ms|║║Cancelling statement #229's schedules...|
|+648ms|║║Executed virtual command clearTile (1ms)|
|+665ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+672ms|║║Cancelling statement #229's schedules...|
|+677ms|║║Executed virtual command clearTile (0ms)|
|+694ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+701ms|║║Cancelling statement #229's schedules...|
|+706ms|║║Executed virtual command clearTile (1ms)|
|+724ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+732ms|║║Cancelling statement #229's schedules...|
|+738ms|║║Executed virtual command clearTile (1ms)|
|+756ms|║║Calculating (integer) 4 + (integer) 1 >> (integer) 5|
|+764ms|║║Cancelling statement #229's schedules...|
|+769ms|║║Executed virtual command clearTile (1ms)|
|+775ms|║║Cancelling statement #206's schedules...|
|+789ms|║║Calculating (decimal) 0.0 - (decimal) 1.0 >> (decimal) -1.0|
|+885ms|║║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object|
|+887ms|║╚Execution stage complete. (726ms)|
|+891ms|║Setting up scheduled job for Thu, Jan 3 2019 @ 4:19:13 PM GMT (in 104.32s)|
|+902ms|╚Event processed successfully (902ms)|
And then the Kitchen Worktop lights turned off with the following in the IDE logs:
16:21:42: info ╚ Received event [Kitchen worktop].switch = turningOff with a delay of 84ms
I should say this is a piston based on the ones created on the wiki here: https://wiki.webcore.co/Device_Tiles#Light_Bulb_Status_Tiles
- I reused
Glad you got it working.
