I request my light to be at 40% light however it turns it on 100% I use the 40% command to turn on the light.
Light being at 40%
Light goes on 100%
22-5-2020 22:16:45 +929ms
+0ms ╔Received event [Pisastraat 73].mode = Home with a delay of 39ms
+43ms ║RunTime Analysis CS > 23ms > PS > 4ms > PE > 15ms > CE
+45ms ║Runtime (40562 bytes) successfully initialized in 4ms (v0.3.110.20191009) (44ms)
+46ms ║╔Execution stage started
+88ms ║║Comparison (time) 80205980 is_not_between (datetime) 1590118560000 … (datetime) 1590176160000 = true (6ms)
+89ms ║║Time restriction check passed
+91ms ║║Condition #2 evaluated true (41ms)
+94ms ║║Comparison (string) :3df1447924a0d97fd4a87ea8793edd1b: changes_to (string) :3df1447924a0d97fd4a87ea8793edd1b: = true (0ms)
+96ms ║║Cancelling condition #40’s schedules…
+97ms ║║Condition #40 evaluated true (5ms)
+98ms ║║Cancelling condition #16’s schedules…
+99ms ║║Condition group #16 evaluated true (state changed) (49ms)
+101ms ║║Cancelling statement #19’s schedules…
+124ms ║║Executed physical command [Driepoot].setLevel([100]) (16ms)
+125ms ║║Executed virtual command [Driepoot].adjustLevel (20ms)
+128ms ║║Cancelling statement #34’s schedules…
+154ms ║║Executed physical command [Hoek plant].setLevel([100]) (19ms)
+155ms ║║Executed virtual command [Hoek plant].adjustLevel (23ms)
+158ms ║║Cancelling statement #36’s schedules…
+175ms ║║Executed physical command [Keuken LED strip].on() (14ms)
+176ms ║║Executed [Keuken LED strip].on (16ms)
+178ms ║║Cancelling statement #38’s schedules…
+197ms ║║Executed physical command [Openhaard].on() (15ms)
+198ms ║║Executed [Openhaard].on (17ms)
+203ms ║╚Execution stage complete. (157ms)
+205ms ║Setting up scheduled job for Sat, May 23 2020 @ 8:36:00 PM CEST (in 80353.867s)
+219ms ╚Event processed successfully (219ms)
