I recently returned after being away for a week and noticed that my Lurton Caseta Dimmers are no longer fading on to a given percentage in Webcore. What has changed since I have been away?
I have been using the “Fade Level” for about 2 years now in pistons, but it appears to cause errors now.
The dimmers are not fading ON by the input percentage.
Below follows a test piston that I have been using to trouble shoot the issue. This has always worked for me.
As you can see at +98ms I am now getting a java error that states command is not supported.
I can dim it in Smarthings and using Alexa.
5/1/2022, 6:53:09 PM +222ms
+0ms ╔Received event [My home].time = 1651445580000 with a delay of 9221ms
+53ms ║RunTime Analysis CS > 19ms > PS > 22ms > PE > 13ms > CE
+55ms ║Runtime (42186 bytes) successfully initialized in 22ms (v0.3.114.20220203) (54ms)
+56ms ║╔Execution stage started
+63ms ║║Comparison (time) 67989283 happens_daily_at (time) 67980000 = true (0ms)
+64ms ║║Time restriction check passed
+66ms ║║Cancelling condition #2’s schedules…
+67ms ║║Condition #2 evaluated true (5ms)
+68ms ║║Cancelling statement #2’s schedules…
+71ms ║║Requesting time schedule wake up at Mon, May 2 2022 @ 6:53:00 PM EDT
+73ms ║║Cancelling condition #1’s schedules…
+74ms ║║Condition group #1 evaluated true (state changed) (13ms)
+76ms ║║Cancelling statement #3’s schedules…
+98ms ║║Error while executing physical command Media Room Light.setLevel([20]): java.lang.IllegalArgumentException: Command ‘setLevel’ is not supported by device 53c905fd-71fe-474d-a973-529a77e9f4bf of type ‘placeholder’. Supported commands: [on, off, refresh, ping]
+100ms ║║Executed virtual command [Media Room Light].fadeLevel (18ms)
+102ms ║╚Execution stage complete. (46ms)
+104ms ║Setting up scheduled job for Mon, May 2 2022 @ 6:53:00 PM EDT (in 86390s)
+111ms ╚Event processed successfully (111ms)
Marking this as resolved as it is a duplicate of what can be found here
