Managing two locations
I have two locations. Home and office. I currently can’t create a piston for the office or I don’t know how.
Does anyone have the solution for having two locations (one hub at each location)? I am very new to this process. If you do have the answer, please use a step by step. I am just learning.
Thanks for your understanding.
You’ll need to install a webCoRE instance into each location.
Hopefully, the info there will help … for two locations under the same account … and you don’t run into the same problem that @bwp98h has …
