I have been playing with this for a couple of months, and tried using some of the pistons I have found here with no luck. I can get notifications, but something (s) are missing. I am using SmartThings Hub, with Zooz ZEN15 Power Switch. Would like to alert when/if freezer power goes out so that I don’t loose food. I understand that ST hub only captures the power monitor at different intervals, and that a power failure only keeps a given power variable ie (Watts) as if it is still reporting to the ST hub.
After much thought this is what I would like to see happen.
- The piston will poll ST/Zooz once per hour (top of hour)
- If after 4 consecutive polls/hours the W have not changed (or other power variable if that is better)
- Initiate notification via text/email/push
For testing purposes I have it currently set at 15 minute polling, and I get notifications but it is sending regardless of change in power variables.
**4)
8/21/2019, 4:29:39 PM +750ms
+123ms +Stopping piston…
+195ms +Piston successfully stopped (73ms)
8/21/2019, 4:29:39 PM +515ms
+119ms +Stopping piston…
+217ms +Piston successfully stopped (98ms)
8/21/2019, 4:29:10 PM +834ms
+2ms +Received event [Zooz Freezer].power = 104.03 with a delay of 96ms
+119ms ¦RunTime Analysis CS > 21ms > PS > 24ms > PE > 73ms > CE
+122ms ¦Runtime (38785 bytes) successfully initialized in 24ms (v0.3.10c.20190522) (119ms)
+123ms ¦+Execution stage started
+130ms ¦+Execution stage complete. (8ms)
+132ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 83.365s)
+145ms +Event processed successfully (144ms)
8/21/2019, 4:28:40 PM +551ms
+2ms +Received event [Zooz Freezer].power = 104.34 with a delay of 111ms
+100ms ¦RunTime Analysis CS > 24ms > PS > 26ms > PE > 49ms > CE
+102ms ¦Runtime (38786 bytes) successfully initialized in 26ms (v0.3.10c.20190522) (100ms)
+104ms ¦+Execution stage started
+109ms ¦+Execution stage complete. (6ms)
+111ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 113.669s)
+123ms +Event processed successfully (122ms)
8/21/2019, 4:28:10 PM +966ms
+2ms +Received event [Zooz Freezer].power = 104.24 with a delay of 222ms
+102ms ¦RunTime Analysis CS > 23ms > PS > 27ms > PE > 52ms > CE
+105ms ¦Runtime (38786 bytes) successfully initialized in 27ms (v0.3.10c.20190522) (101ms)
+106ms ¦+Execution stage started
+148ms ¦+Execution stage complete. (43ms)
+150ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 143.214s)
+165ms +Event processed successfully (165ms)
8/21/2019, 4:27:40 PM +855ms
+2ms +Received event [Zooz Freezer].power = 104.55 with a delay of 110ms
+101ms ¦RunTime Analysis CS > 22ms > PS > 28ms > PE > 51ms > CE
+105ms ¦Runtime (38786 bytes) successfully initialized in 28ms (v0.3.10c.20190522) (101ms)
+144ms ¦+Execution stage complete. (38ms)
+146ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 173.33s)
+172ms +Event processed successfully (172ms)
8/21/2019, 4:27:11 PM +171ms
+1ms +Received event [Zooz Freezer].power = 104.86 with a delay of 189ms
+103ms ¦RunTime Analysis CS > 23ms > PS > 26ms > PE > 54ms > CE
+106ms ¦Runtime (38786 bytes) successfully initialized in 26ms (v0.3.10c.20190522) (103ms)
+107ms ¦+Execution stage started
+112ms ¦+Execution stage complete. (6ms)
+114ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 203.046s)
+124ms +Event processed successfully (124ms)
8/21/2019, 4:26:41 PM +990ms
+2ms +Received event [Zooz Freezer].power = 104.76 with a delay of 1264ms
+125ms ¦RunTime Analysis CS > 28ms > PS > 27ms > PE > 70ms > CE
+127ms ¦Runtime (38787 bytes) successfully initialized in 27ms (v0.3.10c.20190522) (122ms)
+129ms ¦+Execution stage started
+198ms ¦+Execution stage complete. (70ms)
+206ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 232.135s)
+218ms +Event processed successfully (218ms)
8/21/2019, 4:26:10 PM +779ms
+2ms +Received event [Zooz Freezer].power = 104.86 with a delay of 233ms
+107ms ¦RunTime Analysis CS > 23ms > PS > 27ms > PE > 57ms > CE
+110ms ¦Runtime (38786 bytes) successfully initialized in 27ms (v0.3.10c.20190522) (108ms)
+111ms ¦+Execution stage started
+145ms ¦+Execution stage complete. (34ms)
+147ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 263.405s)
+158ms +Event processed successfully (158ms)
8/21/2019, 4:25:40 PM +828ms
+1ms +Received event [Zooz Freezer].power = 105.35 with a delay of 270ms
+99ms ¦RunTime Analysis CS > 21ms > PS > 25ms > PE > 54ms > CE
+102ms ¦Runtime (38785 bytes) successfully initialized in 25ms (v0.3.10c.20190522) (99ms)
+103ms ¦+Execution stage started
+108ms ¦+Execution stage complete. (6ms)
+110ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 293.393s)
+122ms +Event processed successfully (122ms)
8/21/2019, 4:25:11 PM +902ms
+3ms +Received event [Zooz Freezer].power = 105.66 with a delay of 1360ms
+112ms ¦RunTime Analysis CS > 25ms > PS > 23ms > PE > 65ms > CE
+115ms ¦Runtime (38787 bytes) successfully initialized in 23ms (v0.3.10c.20190522) (110ms)
+116ms ¦+Execution stage started
+177ms ¦+Execution stage complete. (62ms)
+184ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 322.245s)
+194ms +Event processed successfully (194ms)
8/21/2019, 4:24:41 PM +59ms
+2ms +Received event [Zooz Freezer].power = 105.35 with a delay of 239ms
+109ms ¦RunTime Analysis CS > 31ms > PS > 27ms > PE > 50ms > CE
+111ms ¦Runtime (38786 bytes) successfully initialized in 27ms (v0.3.10c.20190522) (109ms)
+112ms ¦+Execution stage started
+136ms ¦+Execution stage complete. (24ms)
+138ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 353.134s)
+150ms +Event processed successfully (150ms)
8/21/2019, 4:24:10 PM +944ms
+1ms +Received event [Zooz Freezer].power = 105.45 with a delay of 201ms
+107ms ¦RunTime Analysis CS > 24ms > PS > 28ms > PE > 56ms > CE
+110ms ¦Runtime (38786 bytes) successfully initialized in 28ms (v0.3.10c.20190522) (108ms)
+149ms ¦+Execution stage complete. (38ms)
+151ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 383.236s)
+163ms +Event processed successfully (163ms)
8/21/2019, 4:23:40 PM +856ms
+2ms +Received event [Zooz Freezer].power = 105.76 with a delay of 113ms
+111ms ¦RunTime Analysis CS > 23ms > PS > 34ms > PE > 53ms > CE
+114ms ¦Runtime (38786 bytes) successfully initialized in 34ms (v0.3.10c.20190522) (112ms)
+150ms ¦+Execution stage complete. (35ms)
+152ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 413.323s)
+173ms +Event processed successfully (172ms)
8/21/2019, 4:23:03 PM +221ms
+3ms +Received event [Zooz Freezer].power = 105.87 with a delay of 1378ms
+132ms ¦RunTime Analysis CS > 29ms > PS > 28ms > PE > 75ms > CE
+135ms ¦Runtime (38787 bytes) successfully initialized in 28ms (v0.3.10c.20190522) (129ms)
+136ms ¦+Execution stage started
+241ms ¦+Execution stage complete. (106ms)
+253ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 450.858s)
+267ms +Event processed successfully (267ms)
8/21/2019, 4:22:40 PM +651ms
+1ms +Received event [Zooz Freezer].power = 105.76 with a delay of 116ms
+104ms ¦RunTime Analysis CS > 23ms > PS > 26ms > PE > 55ms > CE
+106ms ¦Runtime (38786 bytes) successfully initialized in 26ms (v0.3.10c.20190522) (104ms)
+154ms ¦+Execution stage complete. (47ms)
+155ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 473.524s)
+168ms +Event processed successfully (168ms)
8/21/2019, 4:22:11 PM +109ms
+1ms +Received event [Zooz Freezer].power = 105.66 with a delay of 104ms
+96ms ¦RunTime Analysis CS > 20ms > PS > 25ms > PE > 50ms > CE
+98ms ¦Runtime (38785 bytes) successfully initialized in 25ms (v0.3.10c.20190522) (96ms)
+99ms ¦+Execution stage started
+104ms ¦+Execution stage complete. (5ms)
+105ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 503.116s)
+119ms +Event processed successfully (119ms)
8/21/2019, 4:21:40 PM +651ms
+2ms +Received event [Zooz Freezer].power = 106.08 with a delay of 114ms
+96ms ¦RunTime Analysis CS > 21ms > PS > 24ms > PE > 50ms > CE
+99ms ¦Runtime (38785 bytes) successfully initialized in 24ms (v0.3.10c.20190522) (97ms)
+101ms ¦+Execution stage started
+135ms ¦+Execution stage complete. (35ms)
+137ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 533.543s)
+147ms +Event processed successfully (147ms)
8/21/2019, 4:20:41 PM +31ms
+2ms +Received event [Zooz Freezer].power = 105.76 with a delay of 100ms
+101ms ¦RunTime Analysis CS > 23ms > PS > 24ms > PE > 54ms > CE
+104ms ¦Runtime (38786 bytes) successfully initialized in 24ms (v0.3.10c.20190522) (101ms)
+105ms ¦+Execution stage started
+110ms ¦+Execution stage complete. (6ms)
+112ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 593.188s)
+123ms +Event processed successfully (123ms)
8/21/2019, 4:20:12 PM +199ms
+1ms +Received event [Zooz Freezer].power = 105.35 with a delay of 233ms
+100ms ¦RunTime Analysis CS > 21ms > PS > 24ms > PE > 54ms > CE
+102ms ¦Runtime (38786 bytes) successfully initialized in 24ms (v0.3.10c.20190522) (100ms)
+110ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 622.021s)
+121ms +Event processed successfully (121ms)
8/21/2019, 4:19:40 PM +984ms
+1ms +Received event [Zooz Freezer].power = 104.86 with a delay of 227ms
+109ms ¦RunTime Analysis CS > 30ms > PS > 28ms > PE > 51ms > CE
+111ms ¦Runtime (38786 bytes) successfully initialized in 28ms (v0.3.10c.20190522) (109ms)
+145ms ¦+Execution stage complete. (33ms)
+146ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 653.2s)
+160ms +Event processed successfully (160ms)
8/21/2019, 4:19:10 PM +849ms
+2ms +Received event [Zooz Freezer].power = 105.66 with a delay of 110ms
+107ms ¦RunTime Analysis CS > 24ms > PS > 27ms > PE > 55ms > CE
+110ms ¦Runtime (38786 bytes) successfully initialized in 27ms (v0.3.10c.20190522) (106ms)
+149ms ¦+Execution stage complete. (39ms)
+151ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 683.331s)
+177ms +Event processed successfully (177ms)
8/21/2019, 4:18:40 PM +745ms
+1ms +Received event [Zooz Freezer].power = 105.76 with a delay of 104ms
+102ms ¦RunTime Analysis CS > 25ms > PS > 27ms > PE > 51ms > CE
+105ms ¦Runtime (38786 bytes) successfully initialized in 27ms (v0.3.10c.20190522) (102ms)
+167ms ¦+Execution stage complete. (62ms)
+176ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 713.411s)
+190ms +Event processed successfully (189ms)
8/21/2019, 4:18:10 PM +904ms
+1ms +Received event [Zooz Freezer].power = 112.48 with a delay of 212ms
+108ms ¦RunTime Analysis CS > 25ms > PS > 29ms > PE > 55ms > CE
+111ms ¦Runtime (38786 bytes) successfully initialized in 29ms (v0.3.10c.20190522) (108ms)
+163ms ¦+Execution stage complete. (51ms)
+165ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 743.262s)
+178ms +Event processed successfully (179ms)
8/21/2019, 4:17:40 PM +749ms
+1ms +Received event [Zooz Freezer].power = 128.05 with a delay of 101ms
+98ms ¦RunTime Analysis CS > 24ms > PS > 25ms > PE > 49ms > CE
+101ms ¦Runtime (38785 bytes) successfully initialized in 25ms (v0.3.10c.20190522) (99ms)
+102ms ¦+Execution stage started
+134ms ¦+Execution stage complete. (33ms)
+135ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 773.446s)
+148ms +Event processed successfully (147ms)
8/21/2019, 4:17:27 PM +435ms
+2ms +Received event [Zooz Freezer].power = 125.31 with a delay of 94ms
+104ms ¦RunTime Analysis CS > 25ms > PS > 26ms > PE > 52ms > CE
+106ms ¦Runtime (38785 bytes) successfully initialized in 26ms (v0.3.10c.20190522) (104ms)
+164ms ¦+Execution stage complete. (57ms)
+165ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 786.73s)
+178ms +Event processed successfully (178ms)
8/21/2019, 4:17:20 PM +456ms
+1ms +Received event [Zooz Freezer].power = 113.83 with a delay of 123ms
+115ms ¦RunTime Analysis CS > 26ms > PS > 31ms > PE > 58ms > CE
+118ms ¦Runtime (38786 bytes) successfully initialized in 31ms (v0.3.10c.20190522) (115ms)
+119ms ¦+Execution stage started
+185ms ¦+Execution stage complete. (67ms)
+195ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 793.681s)
+209ms +Event processed successfully (209ms)
8/21/2019, 4:17:17 PM +427ms
+2ms +Received event [Zooz Freezer].power = 98.23 with a delay of 95ms
+107ms ¦RunTime Analysis CS > 23ms > PS > 26ms > PE > 57ms > CE
+109ms ¦Runtime (38784 bytes) successfully initialized in 26ms (v0.3.10c.20190522) (107ms)
+110ms ¦+Execution stage started
+135ms ¦+Execution stage complete. (24ms)
+136ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 796.767s)
8/21/2019, 4:17:16 PM +433ms
+1ms +Received event [Zooz Freezer].power = 756.33 with a delay of 99ms
+96ms ¦RunTime Analysis CS > 22ms > PS > 24ms > PE > 51ms > CE
+99ms ¦Runtime (38784 bytes) successfully initialized in 24ms (v0.3.10c.20190522) (95ms)
+100ms ¦+Execution stage started
+132ms ¦+Execution stage complete. (33ms)
+134ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 797.764s)
+146ms +Event processed successfully (145ms)
8/21/2019, 4:17:12 PM +440ms
+1ms +Received event [Zooz Freezer].power = 4.11 with a delay of 106ms
+104ms ¦RunTime Analysis CS > 25ms > PS > 27ms > PE > 51ms > CE
+106ms ¦Runtime (38784 bytes) successfully initialized in 27ms (v0.3.10c.20190522) (104ms)
+118ms ¦+Execution stage complete. (11ms)
+121ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 801.771s)
+137ms +Event processed successfully (137ms)
8/21/2019, 4:15:33 PM +61ms
+1ms +Received event [Starry Night].time = 1566429334330 with a delay of -1269ms
+345ms ¦RunTime Analysis CS > 225ms > PS > 38ms > PE > 81ms > CE
+348ms ¦Runtime (38795 bytes) successfully initialized in 38ms (v0.3.10c.20190522) (347ms)
+350ms ¦+Execution stage started
+452ms ¦¦Comparison (decimal) 0.0 did_not_change = true (34ms)
+454ms ¦¦Condition #5 evaluated true (43ms)
+456ms ¦¦Condition group #2 evaluated true (state did not change) (45ms)
+462ms ¦¦Comparison (integer) 1 is_less_than (integer) 3 = true (1ms)
+463ms ¦¦Condition #10 evaluated true (5ms)
+464ms ¦¦Condition group #8 evaluated true (state did not change) (7ms)
+467ms ¦¦Cancelling statement #3’s schedules…
+483ms ¦¦Executed virtual command sendSMSNotification (10ms)
+543ms ¦¦Executed virtual command sendPushNotification (55ms)
+696ms ¦¦Executed virtual command sendEmail (148ms)
+704ms ¦¦Calculating (integer) 1 + (integer) 1 >> (integer) 2
+710ms ¦¦Executed virtual command setVariable (3ms)
+726ms ¦+Execution stage complete. (377ms)
+735ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:30:34 PM PDT (in 900.535s)
+745ms +Event processed successfully (744ms)
8/21/2019, 4:00:46 PM +131ms
+31ms +Received event [Starry Night].time = 1566428434330 with a delay of 11800ms
+477ms ¦RunTime Analysis CS > 149ms > PS > 86ms > PE > 242ms > CE
+480ms ¦Runtime (38803 bytes) successfully initialized in 86ms (v0.3.10c.20190522) (416ms)
+482ms ¦+Execution stage started
+1582ms ¦¦Comparison (decimal) 0.0 did_not_change = true (476ms)
+1584ms ¦¦Cancelling condition #5’s schedules…
+1585ms ¦¦Condition #5 evaluated true (491ms)
+1586ms ¦¦Cancelling condition #2’s schedules…
+1587ms ¦¦Condition group #2 evaluated true (state changed) (494ms)
+1596ms ¦¦Comparison (integer) 0 is_less_than (integer) 3 = true (2ms)
+1598ms ¦¦Cancelling condition #10’s schedules…
+1599ms ¦¦Condition #10 evaluated true (8ms)
+1601ms ¦¦Cancelling condition #8’s schedules…
+1602ms ¦¦Condition group #8 evaluated true (state changed) (11ms)
+1604ms ¦¦Cancelling statement #3’s schedules…
+2127ms ¦¦Executed virtual command sendSMSNotification (432ms)
+2180ms ¦¦Executed virtual command sendPushNotification (47ms)
+2994ms ¦¦Executed virtual command sendEmail (807ms)
+3001ms ¦¦Calculating (integer) 0 + (integer) 1 >> (integer) 1
+3009ms ¦¦Executed virtual command setVariable (4ms)
+3476ms ¦+Execution stage complete. (2995ms)
+3809ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:15:34 PM PDT (in 884.419s)
+3818ms +Event processed successfully (3818ms)
8/21/2019, 3:54:24 PM +67ms
+3ms +Received event [Zooz Freezer].power = 0 with a delay of 1730ms
+127ms ¦RunTime Analysis CS > 31ms > PS > 28ms > PE > 68ms > CE
+130ms ¦Runtime (38788 bytes) successfully initialized in 28ms (v0.3.10c.20190522) (124ms)
+131ms ¦+Execution stage started
+204ms ¦+Execution stage complete. (74ms)
+213ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 370.051s)
+227ms +Event processed successfully (226ms)
8/21/2019, 3:54:10 PM +642ms
+1ms +Received event [Zooz Freezer].power = 96.56 with a delay of 105ms
+100ms ¦RunTime Analysis CS > 22ms > PS > 26ms > PE > 53ms > CE
+102ms ¦Runtime (38791 bytes) successfully initialized in 26ms (v0.3.10c.20190522) (100ms)
+122ms ¦+Execution stage complete. (19ms)
+124ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 383.565s)
+136ms +Event processed successfully (137ms)
8/21/2019, 3:53:40 PM +883ms
+2ms +Received event [Zooz Freezer].power = 96.94 with a delay of 225ms
+98ms ¦RunTime Analysis CS > 23ms > PS > 25ms > PE > 50ms > CE
+101ms ¦Runtime (38790 bytes) successfully initialized in 25ms (v0.3.10c.20190522) (99ms)
+120ms ¦+Execution stage complete. (18ms)
+122ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 413.325s)
8/21/2019, 3:53:10 PM +640ms
+1ms +Received event [Zooz Freezer].power = 96.36 with a delay of 101ms
+95ms ¦RunTime Analysis CS > 20ms > PS > 25ms > PE > 51ms > CE
+98ms ¦Runtime (38790 bytes) successfully initialized in 25ms (v0.3.10c.20190522) (96ms)
+105ms ¦+Execution stage complete. (5ms)
+106ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 443.585s)
+117ms +Event processed successfully (117ms)
8/21/2019, 3:52:40 PM +589ms
+1ms +Received event [Zooz Freezer].power = 97.23 with a delay of 99ms
+103ms ¦RunTime Analysis CS > 23ms > PS > 29ms > PE > 52ms > CE
+106ms ¦Runtime (38790 bytes) successfully initialized in 29ms (v0.3.10c.20190522) (103ms)
+113ms ¦+Execution stage complete. (7ms)
+114ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 473.627s)
+127ms +Event processed successfully (127ms)
8/21/2019, 3:52:11 PM +735ms
+1ms +Received event [Zooz Freezer].power = 97.04 with a delay of 113ms
+105ms ¦RunTime Analysis CS > 21ms > PS > 26ms > PE > 57ms > CE
+107ms ¦Runtime (38791 bytes) successfully initialized in 26ms (v0.3.10c.20190522) (105ms)
+108ms ¦+Execution stage started
+114ms ¦+Execution stage complete. (6ms)
+116ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 502.48s)
8/21/2019, 3:51:40 PM +828ms
+2ms +Received event [Zooz Freezer].power = 97.13 with a delay of 96ms
+97ms ¦RunTime Analysis CS > 22ms > PS > 25ms > PE > 49ms > CE
+99ms ¦Runtime (38789 bytes) successfully initialized in 25ms (v0.3.10c.20190522) (97ms)
+105ms ¦+Execution stage complete. (6ms)
+106ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 533.396s)
+118ms +Event processed successfully (118ms)
8/21/2019, 3:51:10 PM +652ms
+1ms +Received event [Zooz Freezer].power = 97.04 with a delay of 102ms
+99ms ¦RunTime Analysis CS > 20ms > PS > 25ms > PE > 54ms > CE
+102ms ¦Runtime (38790 bytes) successfully initialized in 25ms (v0.3.10c.20190522) (99ms)
+110ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 563.569s)
+121ms +Event processed successfully (120ms)
8/21/2019, 3:50:40 PM +647ms
+1ms +Received event [Zooz Freezer].power = 97.13 with a delay of 210ms
+116ms ¦RunTime Analysis CS > 32ms > PS > 31ms > PE > 53ms > CE
+118ms ¦Runtime (38791 bytes) successfully initialized in 31ms (v0.3.10c.20190522) (116ms)
+120ms ¦+Execution stage started
+164ms ¦+Execution stage complete. (45ms)
+166ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 593.518s)
8/21/2019, 3:50:10 PM +635ms
+1ms +Received event [Zooz Freezer].power = 97.04 with a delay of 197ms
+108ms ¦RunTime Analysis CS > 22ms > PS > 26ms > PE > 60ms > CE
+111ms ¦Runtime (38791 bytes) successfully initialized in 26ms (v0.3.10c.20190522) (109ms)
+117ms ¦+Execution stage complete. (6ms)
+119ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 623.577s)
+131ms +Event processed successfully (131ms)
8/21/2019, 3:49:40 PM +754ms
+2ms +Received event [Zooz Freezer].power = 97.71 with a delay of 210ms
+120ms ¦RunTime Analysis CS > 21ms > PS > 26ms > PE > 73ms > CE
+123ms ¦Runtime (38791 bytes) successfully initialized in 26ms (v0.3.10c.20190522) (121ms)
+124ms ¦+Execution stage started
+133ms ¦+Execution stage complete. (9ms)
+136ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 653.44s)
+148ms +Event processed successfully (148ms)
8/21/2019, 3:49:11 PM +16ms
+1ms +Received event [Zooz Freezer].power = 97.13 with a delay of 191ms
+103ms ¦RunTime Analysis CS > 21ms > PS > 28ms > PE > 54ms > CE
+105ms ¦Runtime (38791 bytes) successfully initialized in 28ms (v0.3.10c.20190522) (103ms)
+114ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 683.201s)
+133ms +Event processed successfully (133ms)
8/21/2019, 3:48:40 PM +740ms
+2ms +Received event [Zooz Freezer].power = 97.42 with a delay of 101ms
+109ms ¦Runtime (38791 bytes) successfully initialized in 26ms (v0.3.10c.20190522) (107ms)
+116ms ¦+Execution stage complete. (6ms)
+118ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 713.473s)
+128ms +Event processed successfully (128ms)
8/21/2019, 3:47:40 PM +740ms
+2ms +Received event [Zooz Freezer].power = 97.33 with a delay of 217ms
+97ms ¦RunTime Analysis CS > 22ms > PS > 26ms > PE > 48ms > CE
+99ms ¦Runtime (38790 bytes) successfully initialized in 26ms (v0.3.10c.20190522) (97ms)
+106ms ¦+Execution stage complete. (6ms)
+107ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 773.483s)
+120ms +Event processed successfully (120ms)
8/21/2019, 3:47:10 PM +991ms
+2ms +Received event [Zooz Freezer].power = 97.42 with a delay of 108ms
+108ms ¦RunTime Analysis CS > 24ms > PS > 28ms > PE > 56ms > CE
+111ms ¦Runtime (38791 bytes) successfully initialized in 28ms (v0.3.10c.20190522) (107ms)
+149ms ¦+Execution stage complete. (37ms)
+150ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 803.189s)
8/21/2019, 3:46:40 PM +534ms
+1ms +Received event [Zooz Freezer].power = 97.71 with a delay of 99ms
+105ms ¦RunTime Analysis CS > 22ms > PS > 25ms > PE > 59ms > CE
+108ms ¦Runtime (38790 bytes) successfully initialized in 25ms (v0.3.10c.20190522) (105ms)
+109ms ¦+Execution stage started
+142ms ¦+Execution stage complete. (34ms)
+144ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 833.653s)
+157ms +Event processed successfully (157ms)
8/21/2019, 3:46:10 PM +667ms
+1ms +Received event [Zooz Freezer].power = 97.62 with a delay of 231ms
+103ms ¦RunTime Analysis CS > 22ms > PS > 29ms > PE > 52ms > CE
+105ms ¦Runtime (38791 bytes) successfully initialized in 29ms (v0.3.10c.20190522) (103ms)
+114ms ¦+Execution stage complete. (8ms)
+116ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 863.548s)
8/21/2019, 3:45:42 PM +192ms
+3ms +Received event [Zooz Freezer].power = 97.71 with a delay of 1383ms
+133ms ¦RunTime Analysis CS > 31ms > PS > 29ms > PE > 73ms > CE
+136ms ¦Runtime (38792 bytes) successfully initialized in 29ms (v0.3.10c.20190522) (131ms)
+137ms ¦+Execution stage started
+232ms ¦+Execution stage complete. (96ms)
+242ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 891.898s)
+255ms +Event processed successfully (254ms)
8/21/2019, 3:45:34 PM +768ms
+2ms +Received event [Starry Night].time = 1566427534330 with a delay of 436ms
+181ms ¦RunTime Analysis CS > 51ms > PS > 51ms > PE > 81ms > CE
+185ms ¦Runtime (38797 bytes) successfully initialized in 51ms (v0.3.10c.20190522) (178ms)
+186ms ¦+Execution stage started
+313ms ¦¦Comparison (decimal) 97.84 did_not_change = false (41ms)
+315ms ¦¦Condition #5 evaluated false (53ms)
+316ms ¦¦Condition group #2 evaluated false (state did not change) (56ms)
+319ms ¦¦Cancelling statement #6’s schedules…
+340ms ¦¦Executed virtual command setVariable (5ms)
+378ms ¦+Execution stage complete. (192ms)
+410ms ¦Setting up scheduled job for Wed, Aug 21 2019 @ 4:00:34 PM PDT (in 899.153s)
+420ms +Event processed successfully (421ms)
