I want to turn on 2 lights, inside and outside when someone rings the doorbell and it is “dark” outside. I used 30 min before sunset for this.
As above. I also want the lights to turn off after a set time. For now I have it at 20 mins. I initially had the ‘wait’ command right after the ‘turn on’ command followed by ‘turn off’. This didn’t work so then I had a variable created. It seems like a long work around for something simple. Will the variable be false only after the piston runs?
The lights weren’t turning off. The lights did turn on with the doorbell push. So I changed the piston to what is posted now. As stated above. Wanted feedback. Thanks
