Hello everyone, I need help.
I have three fans to circulate warm air from my wood burning stove.
This is what I am trying to make happen when thermostat reaches 73 deg.
- When the thermostat reaches 73 deg, turn on my living room fan.
- If the living room fan comes on, I want the hall fan to come on.
- If the hall fan has been on for at least 10 minutes, I want it to turn the heat fan on(bedroom fan)
4, If it is between 8 pm and 7 am turn on and keep heat fan on. regardless of temperature.
Then, If it falls to 71 deg. I want it to
- Turn off living room fan
- wait 10 minutes
- Turn off hallway fan
- If it is between 9 am and 7 pm and hallway fan has been off for 5 minutes turn off heat fan
Also, I still want to be able to control living room fan manually at any temperature and keep all the triggers the living room fan triggers.
I have no idea what I am doing and need some guidance.
