When I click on import piston from an external source I get a message saying “you wanted to import a new piston. The bad news is there is no way to do this yet.”
Not able to import pistons
c1arkbar
If you are trying to import a piston someone has shared then use Restore Piston from backup code. Orange button.
Thanks. That worked. However when I open restore there is a note saying that only files created by my account are supported. All others will create a blank piston. Confusing.
