Hi everyone! Hoping you can help me track down this issue. I have two really simple pistons that are to turn on my lights and change my thermostat when my presence sensor changes to present. It works randomly, as in it will be fine for a day or two and than just stops (It did work find the day after the hub update). So i went into webcore to check the piston and it says that it was last executed at the correct time. I next went to my devices and checked the lights and they do show that they seem to get the command to turn them on and set the level but that is not what is happening. The next log event is that lights are off. as you can see from the log below.
Date Source Type Name Value User Displayed Text
2017-11-19 1:02:52.661 PM PST
10 minutes ago DEVICE switch off Front light switch is off
2017-11-19 1:02:40.546 PM PST
10 minutes ago APP_COMMAND setLevel Come home lights sent setLevel command to Front light
2017-11-19 1:02:40.501 PM PST
10 minutes ago APP_COMMAND on Come home lights sent on command to Front light
2017-11-19 1:02:40.024 PM PST
10 minutes ago DEVICE switch on Front light switch is on
2017-11-18 9:47:15.814 PM PST
15 hours ago DEVICE switch off Front light switch is off
Anyone have any idea what I can do to try and fix this issue? I get the same thing for my thermostat as well (says it is doing what the piston state but actually doesn’t). Really appreciate it everyone!
