The push notification is not repeating (when the light remains on) and the trigger of stay any of home, away or vacation is not triggering.
Piston will repeat the push until the light is off.
See #1
**4) Post a Green Snapshot of the
Logs
3/20/2020, 12:32:08 PM +145ms
+0ms ╔Received event [Casa de Pines].time = 1584732729202 with a delay of -1058ms
+287ms ║Runtime (51686 bytes) successfully initialized in 242ms (v0.3.110.20191009) (286ms)
+288ms ║╔Execution stage started
+317ms ║║Executed virtual command setVariable (3ms)
+337ms ║║Executed virtual command sendPushNotification (17ms)
+340ms ║║Executed virtual command setState (0ms)
+344ms ║║Arabella RGBW was left on for more than 2 minutes @12:32 PM 20-Mar-20 MST
+345ms ║║Executed virtual command log (1ms)
+348ms ║╚Execution stage complete. (60ms)
+349ms ╚Event processed successfully (349ms)
3/20/2020, 12:30:08 PM +218ms
+0ms ╔Received event [Casa de Pines].time = 1584732609359 with a delay of -1141ms
+942ms ║Runtime (51686 bytes) successfully initialized in 422ms (v0.3.110.20191009) (940ms)
+943ms ║╔Execution stage started
+988ms ║╚Execution stage complete. (46ms)
+989ms ║Setting up scheduled job for Fri, Mar 20 2020 @ 12:32:09 PM MST (in 119.995s)
+998ms ╚Event processed successfully (998ms)
3/20/2020, 12:29:38 PM +998ms
+1ms ╔Received event [Casa de Pines].test = 1584732578998 with a delay of 0ms
+327ms ║Runtime (51680 bytes) successfully initialized in 271ms (v0.3.110.20191009) (324ms)
+328ms ║╔Execution stage started
+382ms ║╚Execution stage complete. (54ms)
+392ms ║Setting up scheduled job for Fri, Mar 20 2020 @ 12:30:09 PM MST (in 29.97s)
+401ms ╚Event processed successfully (401ms)
