There’s an option to back-up all pistons with a password. Is this functional? If so, where do you retrieve them from? Also, if not functional, do you have to back-up each piston separately and notate each back-up code?
Piston password back-up
Baz2473
As far as I’m aware, the latest I’ve heard is that it’s not currently supported yet. You can backup all pistons but cannot restore all yet.
The only way at the moment to restore pistons is with the individual backup codes.
ady624
Yeah, you can backup all of them and use the password for encryption - it will generate a file that you store on your computer. There’s no restore YET but the files should work when the feature is implemented.
smartie
Well, that was weird…I tried Chrome and it worked…and I saw options, such as move pistons, which I can’t see with Firefox…Confirmed it does not work in Firefox…
