Piston stopped running
Everything was fine until today, i didn’t do anything, yet nothing works.
It seems as the webcore doesn’t update anything, not the devices nor their status (sensor triggers etc).
I can manually trigger executions commands and it works (for example turn light on works).
It might be due to running old Webcore, as i see the message
A newer SmartApp version (v0.2.0fc.20171105) is available, please update and publish all the webCoRE SmartApps in the SmartThings IDE.
However i wasn’t able to update as stated in the wiki. My webcore is through github, but in IDE when i press Update from repo -> WebCoRE (master) -> its all empty.
what did i miss?
Perhaps your github link is broken.
A few people have reported this I believe.
You could manually go the ady624’s github repo and copy and paste in.
I would strongly recommend you update ASAP as you will continue to have issues until you do.
ok updating seems to fix it, except for the simulated switched that i added in smartthings, its not listed in webcore dashboard as device and i can’t select it in a script/piston.
closed #5
