I have a piston that should loop a specific number of times. It works, but erratically. Sometimes the piston will loop 4 times, sometimes 7, sometimes 3 before it stops executing. The piston should stop when a counter reaches 21, and while the variable is incrementing correctly the piston stops executing well before the variable gets set to 21.
I watched the piston run many times and it was accurately scheduling the next iteration of the loop but then crapped out each time. Each time it stops, I see the following message in the log but don’t know what it means or if it’s indicative of something I did wrong when I created the piston:
Received event [Home].execute = recovery with a delay of 202ms
Piston should execute a loop for a specific number of times and then stop.
The piston stops executing even though the variable that controls the loop has not been reached. The number of times the loop is executed before the piston ends varies each time the piston executes.
**5) Attach any logs (From [ST IDE]
9/7/2018, 10:02:55 AM +233ms
+0ms â•”Received event [Home].execute = recovery with a delay of 78ms
+10193ms â•‘RunTime Analysis CS > 23ms > PS > 10141ms > PE > 31ms > CE
+10195ms â•‘Piston waited at a semaphore for 10095ms
+10197ms â•‘Runtime (44770 bytes) successfully initialized in 10141ms (v0.3.108.20180906) (10196ms)
+10198ms â•‘â•”Execution stage started
+10212ms â•‘â•‘Condition #2 evaluated false (8ms)
+10213ms â•‘â•‘Condition group #1 evaluated false (state did not change) (9ms)
+10223ms â•‘â•‘Condition #18 evaluated false (7ms)
+10225ms â•‘â•‘Condition group #17 evaluated false (state did not change) (8ms)
+10227ms ║╚Execution stage complete. (29ms)
+10229ms ╚Event processed successfully (10230ms)
9/7/2018, 10:02:55 AM +507ms
+1ms â•”Received event [Home].execute = recovery with a delay of 190ms
+121ms â•‘RunTime Analysis CS > 22ms > PS > 68ms > PE > 30ms > CE
+123ms â•‘Runtime (44691 bytes) successfully initialized in 68ms (v0.3.108.20180906) (121ms)
+125ms â•‘â•”Execution stage started
+142ms â•‘â•‘Condition #2 evaluated false (10ms)
+143ms â•‘â•‘Condition group #1 evaluated false (state did not change) (11ms)
+152ms â•‘â•‘Condition #18 evaluated false (6ms)
+154ms â•‘â•‘Condition group #17 evaluated false (state did not change) (7ms)
+157ms ║╚Execution stage complete. (32ms)
+158ms ╚Event processed successfully (158ms)
9/7/2018, 10:02:55 AM +121ms
+0ms â•”Received event [Home].execute = recovery with a delay of 211ms
+95ms â•‘RunTime Analysis CS > 17ms > PS > 53ms > PE > 25ms > CE
+97ms â•‘Runtime (44683 bytes) successfully initialized in 53ms (v0.3.108.20180906) (96ms)
+98ms â•‘â•”Execution stage started
+113ms ║║Cancelling condition #2’s schedules…
+114ms â•‘â•‘Condition #2 evaluated false (10ms)
+115ms ║║Cancelling condition #1’s schedules…
+118ms â•‘â•‘Condition group #1 evaluated false (state changed) (12ms)
+128ms ║║Cancelling condition #18’s schedules…
+130ms â•‘â•‘Condition #18 evaluated false (7ms)
+131ms ║║Cancelling condition #17’s schedules…
+132ms â•‘â•‘Condition group #17 evaluated false (state changed) (11ms)
+136ms ║╚Execution stage complete. (38ms)
+137ms ╚Event processed successfully (137ms)
9/7/2018, 9:59:56 AM +138ms
+1ms â•”Received event [Home].time = 1536335997470 with a delay of -1332ms
+107ms â•‘RunTime Analysis CS > 19ms > PS > 59ms > PE > 29ms > CE
+110ms â•‘Runtime (44688 bytes) successfully initialized in 59ms (v0.3.108.20180906) (108ms)
+111ms â•‘â•”Execution stage started
+140ms â•‘â•‘Calculating (string) Door to garage is open. Message + (string) 6 >> (string) Door to garage is open. Message 6
+144ms â•‘â•‘Calculating (string) Door to garage is open. Message 6 + (string) of 20. >> (string) Door to garage is open. Message 6 of 20.
+259ms â•‘â•‘Executed virtual command sendPushNotification (110ms)
+274ms â•‘â•‘Comparison (enum) open is (string) open = true (2ms)
+276ms â•‘â•‘Condition #22 evaluated true (12ms)
+282ms â•‘â•‘Comparison (integer) 6 is_less_than (integer) 21 = true (2ms)
+284ms â•‘â•‘Condition #23 evaluated true (6ms)
+285ms â•‘â•‘Condition group #21 evaluated true (state did not change) (23ms)
+293ms â•‘â•‘Comparison (integer) 6 is_less_than_or_equal_to (integer) 19 = true (2ms)
+295ms â•‘â•‘Condition #25 evaluated true (7ms)
+297ms â•‘â•‘Condition group #24 evaluated true (state did not change) (10ms)
+300ms ║║Cancelling statement #30’s schedules…
+308ms â•‘â•‘Calculating (integer) 6 + (integer) 1 >> (integer) 7
+315ms â•‘â•‘Executed virtual command setVariable (4ms)
+322ms â•‘â•‘Executed virtual command wait (1ms)
+336ms â•‘â•‘Requesting a wake up for Fri, Sep 7 2018 @ 10:00:56 AM MDT (in 60.0s)
+350ms ║╚Execution stage complete. (239ms)
+353ms â•‘Setting up scheduled job for Fri, Sep 7 2018 @ 10:00:56 AM MDT (in 59.992s)
+363ms ╚Event processed successfully (363ms)
9/7/2018, 9:58:57 AM +136ms
+1ms â•”Received event [Home].time = 1536335938261 with a delay of -1126ms
+193ms â•‘RunTime Analysis CS > 89ms > PS > 77ms > PE > 28ms > CE
+196ms â•‘Runtime (44688 bytes) successfully initialized in 77ms (v0.3.108.20180906) (194ms)
+198ms â•‘â•”Execution stage started
+230ms â•‘â•‘Calculating (string) Door to garage is open. Message + (string) 5 >> (string) Door to garage is open. Message 5
+235ms â•‘â•‘Calculating (string) Door to garage is open. Message 5 + (string) of 20. >> (string) Door to garage is open. Message 5 of 20.
+263ms â•‘â•‘Executed virtual command sendPushNotification (22ms)
+278ms â•‘â•‘Comparison (enum) open is (string) open = true (2ms)
+280ms â•‘â•‘Condition #22 evaluated true (13ms)
+287ms â•‘â•‘Comparison (integer) 5 is_less_than (integer) 21 = true (2ms)
+289ms â•‘â•‘Condition #23 evaluated true (8ms)
+291ms â•‘â•‘Condition group #21 evaluated true (state did not change) (24ms)
+301ms â•‘â•‘Comparison (integer) 5 is_less_than_or_equal_to (integer) 19 = true (2ms)
+303ms â•‘â•‘Condition #25 evaluated true (7ms)
+304ms â•‘â•‘Condition group #24 evaluated true (state did not change) (10ms)
+308ms ║║Cancelling statement #30’s schedules…
+318ms â•‘â•‘Calculating (integer) 5 + (integer) 1 >> (integer) 6
+324ms â•‘â•‘Executed virtual command setVariable (3ms)
+331ms â•‘â•‘Executed virtual command wait (1ms)
+333ms â•‘â•‘Requesting a wake up for Fri, Sep 7 2018 @ 9:59:57 AM MDT (in 60.0s)
+342ms ║╚Execution stage complete. (144ms)
+344ms â•‘Setting up scheduled job for Fri, Sep 7 2018 @ 9:59:57 AM MDT (in 59.991s)
+356ms ╚Event processed successfully (355ms)
9/7/2018, 9:57:57 AM +153ms
+1ms â•”Received event [Home].time = 1536335878333 with a delay of -1181ms
+922ms â•‘RunTime Analysis CS > 149ms > PS > 746ms > PE > 27ms > CE
+925ms â•‘Runtime (44691 bytes) successfully initialized in 746ms (v0.3.108.20180906) (921ms)
+926ms â•‘â•”Execution stage started
+959ms â•‘â•‘Calculating (string) Door to garage is open. Message + (string) 4 >> (string) Door to garage is open. Message 4
+964ms â•‘â•‘Calculating (string) Door to garage is open. Message 4 + (string) of 20. >> (string) Door to garage is open. Message 4 of 20.
+1037ms â•‘â•‘Executed virtual command sendPushNotification (67ms)
+1052ms â•‘â•‘Comparison (enum) open is (string) open = true (3ms)
+1054ms â•‘â•‘Condition #22 evaluated true (13ms)
+1062ms â•‘â•‘Comparison (integer) 4 is_less_than (integer) 21 = true (3ms)
+1064ms â•‘â•‘Condition #23 evaluated true (9ms)
+1066ms â•‘â•‘Condition group #21 evaluated true (state did not change) (24ms)
+1074ms â•‘â•‘Comparison (integer) 4 is_less_than_or_equal_to (integer) 19 = true (2ms)
+1077ms â•‘â•‘Condition #25 evaluated true (7ms)
+1078ms â•‘â•‘Condition group #24 evaluated true (state did not change) (10ms)
+1082ms ║║Cancelling statement #30’s schedules…
+1090ms â•‘â•‘Calculating (integer) 4 + (integer) 1 >> (integer) 5
+1097ms â•‘â•‘Executed virtual command setVariable (4ms)
+1105ms â•‘â•‘Executed virtual command wait (1ms)
+1107ms â•‘â•‘Requesting a wake up for Fri, Sep 7 2018 @ 9:58:58 AM MDT (in 60.0s)
+1115ms ║╚Execution stage complete. (190ms)
+1117ms â•‘Setting up scheduled job for Fri, Sep 7 2018 @ 9:58:58 AM MDT (in 59.992s)
+1135ms ╚Event processed successfully (1136ms)
9/7/2018, 9:56:57 AM +244ms
+1ms â•”Received event [Home].time = 1536335818168 with a delay of -924ms
+905ms â•‘RunTime Analysis CS > 131ms > PS > 733ms > PE > 40ms > CE
+909ms â•‘Runtime (44690 bytes) successfully initialized in 733ms (v0.3.108.20180906) (907ms)
+911ms â•‘â•”Execution stage started
+947ms â•‘â•‘Calculating (string) Door to garage is open. Message + (string) 3 >> (string) Door to garage is open. Message 3
+953ms â•‘â•‘Calculating (string) Door to garage is open. Message 3 + (string) of 20. >> (string) Door to garage is open. Message 3 of 20.
+1017ms â•‘â•‘Executed virtual command sendPushNotification (58ms)
+1033ms â•‘â•‘Comparison (enum) open is (string) open = true (3ms)
+1035ms â•‘â•‘Condition #22 evaluated true (14ms)
+1042ms â•‘â•‘Comparison (integer) 3 is_less_than (integer) 21 = true (2ms)
+1044ms â•‘â•‘Condition #23 evaluated true (8ms)
+1045ms â•‘â•‘Condition group #21 evaluated true (state did not change) (25ms)
+1055ms â•‘â•‘Comparison (integer) 3 is_less_than_or_equal_to (integer) 19 = true (2ms)
+1057ms â•‘â•‘Condition #25 evaluated true (8ms)
+1058ms â•‘â•‘Condition group #24 evaluated true (state did not change) (10ms)
+1062ms ║║Cancelling statement #30’s schedules…
+1070ms â•‘â•‘Calculating (integer) 3 + (integer) 1 >> (integer) 4
+1078ms â•‘â•‘Executed virtual command setVariable (5ms)
+1086ms â•‘â•‘Executed virtual command wait (1ms)
+1088ms â•‘â•‘Requesting a wake up for Fri, Sep 7 2018 @ 9:57:58 AM MDT (in 60.0s)
+1096ms ║╚Execution stage complete. (186ms)
+1099ms â•‘Setting up scheduled job for Fri, Sep 7 2018 @ 9:57:58 AM MDT (in 59.991s)
+1112ms ╚Event processed successfully (1112ms)
9/7/2018, 9:55:57 AM +606ms
+1ms â•”Received event [Home].time = 1536335757542 with a delay of 64ms
+353ms â•‘RunTime Analysis CS > 169ms > PS > 155ms > PE > 28ms > CE
+356ms â•‘Runtime (44688 bytes) successfully initialized in 155ms (v0.3.108.20180906) (353ms)
+358ms â•‘â•”Execution stage started
+401ms â•‘â•‘Calculating (string) Door to garage is open. Message + (string) 2 >> (string) Door to garage is open. Message 2
+407ms â•‘â•‘Calculating (string) Door to garage is open. Message 2 + (string) of 20. >> (string) Door to garage is open. Message 2 of 20.
+479ms â•‘â•‘Executed virtual command sendPushNotification (65ms)
+496ms â•‘â•‘Comparison (enum) open is (string) open = true (4ms)
+499ms â•‘â•‘Condition #22 evaluated true (15ms)
+506ms â•‘â•‘Comparison (integer) 2 is_less_than (integer) 21 = true (2ms)
+509ms â•‘â•‘Condition #23 evaluated true (8ms)
+510ms â•‘â•‘Condition group #21 evaluated true (state did not change) (27ms)
+519ms â•‘â•‘Comparison (integer) 2 is_less_than_or_equal_to (integer) 19 = true (2ms)
+521ms â•‘â•‘Condition #25 evaluated true (7ms)
+523ms â•‘â•‘Condition group #24 evaluated true (state did not change) (9ms)
+527ms ║║Cancelling statement #30’s schedules…
+536ms â•‘â•‘Calculating (integer) 2 + (integer) 1 >> (integer) 3
+548ms â•‘â•‘Executed virtual command setVariable (8ms)
+558ms â•‘â•‘Executed virtual command wait (1ms)
+561ms â•‘â•‘Requesting a wake up for Fri, Sep 7 2018 @ 9:56:58 AM MDT (in 60.0s)
+572ms ║╚Execution stage complete. (215ms)
+575ms â•‘Setting up scheduled job for Fri, Sep 7 2018 @ 9:56:58 AM MDT (in 59.988s)
+587ms ╚Event processed successfully (586ms)
9/7/2018, 9:54:57 AM +352ms
+1ms â•”Received event [Door to Garage].contact = open with a delay of 107ms
+87ms â•‘RunTime Analysis CS > 21ms > PS > 47ms > PE > 19ms > CE
+89ms â•‘Runtime (44696 bytes) successfully initialized in 47ms (v0.3.108.20180906) (87ms)
+90ms â•‘â•”Execution stage started
+101ms â•‘â•‘Comparison (enum) open changes_to (string) open = true (1ms)
+103ms ║║Cancelling condition #2’s schedules…
+104ms â•‘â•‘Condition #2 evaluated true (8ms)
+105ms ║║Cancelling condition #1’s schedules…
+106ms â•‘â•‘Condition group #1 evaluated true (state changed) (10ms)
+109ms ║║Cancelling statement #7’s schedules…
+116ms â•‘â•‘Executed virtual command setVariable (3ms)
+131ms â•‘â•‘Executed virtual command sendPushNotification (10ms)
+141ms â•‘â•‘Comparison (enum) open is (string) open = true (2ms)
+143ms â•‘â•‘Condition #22 evaluated true (7ms)
+148ms â•‘â•‘Comparison (integer) 1 is_less_than (integer) 21 = true (2ms)
+150ms â•‘â•‘Condition #23 evaluated true (6ms)
+152ms â•‘â•‘Condition group #21 evaluated true (state did not change) (17ms)
+160ms â•‘â•‘Comparison (integer) 1 is_less_than_or_equal_to (integer) 19 = true (2ms)
+162ms â•‘â•‘Condition #25 evaluated true (7ms)
+163ms â•‘â•‘Condition group #24 evaluated true (state did not change) (9ms)
+167ms ║║Cancelling statement #30’s schedules…
+174ms â•‘â•‘Calculating (integer) 1 + (integer) 1 >> (integer) 2
+180ms â•‘â•‘Executed virtual command setVariable (3ms)
+187ms â•‘â•‘Executed virtual command wait (1ms)
+189ms â•‘â•‘Requesting a wake up for Fri, Sep 7 2018 @ 9:55:57 AM MDT (in 60.0s)
+196ms ║╚Execution stage complete. (106ms)
+198ms â•‘Setting up scheduled job for Fri, Sep 7 2018 @ 9:55:57 AM MDT (in 59.993s)
+209ms ╚Event processed successfully (209ms)
9/7/2018, 9:54:56 AM +102ms
+1ms â•”Received event [Home].time = 1536335697770 with a delay of -1669ms
+223ms â•‘RunTime Analysis CS > 116ms > PS > 87ms > PE > 20ms > CE
+226ms â•‘Runtime (44696 bytes) successfully initialized in 87ms (v0.3.108.20180906) (224ms)
+227ms â•‘â•”Execution stage started
+228ms ║╚Execution stage complete. (2ms)
+230ms ╚Event processed successfully (230ms)
Clear
Full Nothing selected None Minimal Medium Full
Logging level
Variables
Local variables
integertimesToWarn 7
integerintervalToWarn1
Global variables
boolean@firstTimeThroughtrue
boolean@holdMotionNotificationsfalse
boolean@sendSetpointChangeMessagetrue
boolean@sendSpeakNotificationstrue
dynamic@timeDogWasFedDayFriday
time@timeDogWasFedTime3:03:00 PM
boolean@turnPatioLightsOntrue
System variables
dynamic$argsnull
integer$day7
integer$dayOfWeek5
string$dayOfWeekNameFriday
device$deviceLocation
device$devicesLocation
integer$hour9
integer$hour249
string$httpContentType
integer$httpStatusCode
boolean$httpStatusOk
integer$iftttStatusCode
boolean$iftttStatusOk
dynamic$incidentsnull
decimal$index
dynamic$jsonnull
datetime$localNow1536313772031
device$locationLocation
string$locationModeHome
integer$mediaSize0
string$meridianAM
string$meridianWithDotsA.M.
datetime$midnight9/7/2018, 12:00:00 AM
integer$minute49
integer$month9
string$monthNameSeptember
string$nameSide Gate is Open
datetime$nextMidnight9/8/2018, 12:00:00 AM
datetime$nextNoon9/7/2018, 12:00:00 PM
datetime$nextScheduledTimeInvalid Date
datetime$nextSunrise9/8/2018, 6:33:00 AM
datetime$nextSunset9/7/2018, 7:21:00 PM
dynamic$nflnull
datetime$noon9/7/2018, 12:00:00 PM
datetime$now9/7/2018, 9:49:32 AM
dynamic$placesnull
