when I use the “set color” command, the log shows that it’s also setting the level to 50, even if I didn’t send a “set level” command, and the level was something else, i.e. 80.
to get around this, I can immediately send a “set level” command to the value I want, but sometimes I can see the light try to switch to 50 and then quickly to 80, so that’s not ideal.
Is it possible to simply omit the “level” portion, when using the set color command?
