I’ve been trying out the Fade Hue emulation and it appears to only Fade forward, not backwards. I was wondering if this is by design or if it’s possible to Fade backwards Example: Start at Purple (Hue 294) to Red (Hue 360) over 60 seconds works as expected, but the other way (Hue 360 to Hue 294) doesn’t seem to work.
For the Fade Hue to move in negative increments.
Using a starting point of 360 moving to 294 , the Piston stops executing
(5/4/2018, 11:45:45 AM +503ms
+1ms ╔Received event [Collinwood].time = 1525459546377 with a delay of -874ms
+138ms ║RunTime Analysis CS > 18ms > PS > 47ms > PE > 73ms > CE
+140ms ║Runtime (37408 bytes) successfully initialized in 47ms (v0.3.104.20180323) (139ms)
+186ms ║║Executed physical command [lightify test].setHue([100]) (39ms)
+189ms ║║Fast executing schedules, waiting for 785ms to sync up
+998ms ║║Executed physical command [lightify test].setHue([100]) (18ms)
+1009ms ║╚Execution stage complete. (868ms)
+1010ms ╚Event processed successfully (1010ms))
