Sorry if this is endlessly discussed elsewhere, I’ve just found webCoRE and this forum. I missed the boat on Echo Speaks, it wasn’t installed before they killed it. Is there another alternative that can make an announcement on an Echo and/or a Google Home/Nest device?
Replacement for Echo Speaks?
jkp
the developer is still working on an Echo Speaks lite version so watch the Echo Speaks thread on the ST forum.
as a temporary solution, you can check out the following thread
Pantheon
Using webcore, I used the Echo devices created by ES to play my Amazon Prime playlists using the searchMusic command. I am playing with Voice Monkey to do speech/announcements. I want to use webcore to tell an Echo device to play a particular playlist like it did in ES. Any idea how to replicate the searchMusic command in webcore with possibly a GET or similar?
