@WCmore
So, are these the only things I need to modify in order to use it?
- the bulb/device being used
- what I want it to do between Capture and Restore
…or do I need to do something with the variables or anything else?
Also, I see this in a lot of Pistons (including this one)…
…usually with a number in it.
What is it for, and do I need to do anything there with this one?
UPDATE: Actually, I just tried it, and it worked. So, thanks!
I think I may be able to poke around a little bit and figure out how this works, but for now, I at least have something I can duplicate elsewhere if I want to.
Something else… when it Restores, it turns it ON, even if it was off prior to the Capture.
Is there any way of getting it to Restore without turning it on, or do I basically need to tell it to turn it back off after a Restore?
