eh … no worries. may be do it incrementally.
pretty good. things seem to be working fine.
no plans to remove … may add another option for folks that dont have a contact sensor on their main doors.
i did notice today that the restore function didn’t work and it spoking in the lower music volume rather than the higher level i have set. Has there been any changes?
possibly the previous one, as after i posted i noticed you had created a update and although the latest update did restore the music I didn’t notice it turn up the volume.
checking … what type of speaker device?
also can you please check the IDE logs for the speaker device and post what volume it shows there?
SONOS.
Just had a thought I had them grouped at the time, would that have messed with it?
looks like they were sent.
I didn’t have logging on yet so will get some logs if it happens again
ungrouped at high volume then at a low
40813844-f043-48d0-9191-0b21fc47cf77 17:43:11: info Dining Room SONOS is playing BBC Radio 1
40813844-f043-48d0-9191-0b21fc47cf77 17:43:11: trace Current status: 'playing', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:43:11: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:43:10: debug Not parsing XML message:
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body>
<u:StopResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1">
</u:StopResponse>
</s:Body>
</s:Envelope>
<e:propertyset xmlns:e="urn:schemas-upnp-org:event-1-0">
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;TRANSITIONING&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;9&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;hls-radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:00&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;sonos.com-http:*:audio/mpegurl:*&amp;quot;&amp;gt;x-sonosapi-stream:s24939?sid=254&amp;amp;amp;flags=8224&amp;amp;amp;sn=0&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;ZPSTR_CONNECTING&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;upnp:albumArtURI&amp;gt;/getaa?s=1&amp;amp;amp;u=x-sonosapi-stream%3as24939%3fsid%3d254%26flags%3d8224%26sn%3d0&amp;lt;/upnp:albumArtURI&amp;gt;&amp;lt;dc:...[TRUNCATED]
<s:Body>
<u:PlayResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1">
</u:PlayResponse>
</s:Body>
</s:Envelope>
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;STOPPED&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;9&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;x-rincon-mp3radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:00&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;sonos.com-http:*:audio/mpegurl:*&amp;quot;&amp;gt;x-sonosapi-stream:s24939?sid=254&amp;amp;amp;flags=8224&amp;amp;amp;sn=0&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;upnp:albumArtURI&amp;gt;/getaa?s=1&amp;amp;amp;u=x-sonosapi-stream%3as24939%3fsid%3d254%26flags%3d8224%26sn%3d0&amp;lt;/upnp:albumArtURI&amp;gt;&amp;lt;dc:title&amp;...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:43:10: trace Skipping event generation for sound file x-rincon-mp3radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8
40813844-f043-48d0-9191-0b21fc47cf77 17:43:09: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:43:10: trace Current status: 'stopped', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:43:09: debug Not parsing XML message:
<s:Body>
<u:SetAVTransportURIResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1">
</u:SetAVTransportURIResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:43:08: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/RCS/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;Volume channel=&quot;Master&quot; val=&quot;20&quot;/&gt;&lt;Volume channel=&quot;LF&quot; val=&quot;100&quot;/&gt;&lt;Volume channel=&quot;RF&quot; val=&quot;100&quot;/&gt;&lt;/InstanceID&gt;&lt;/Event&gt;
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:43:08: trace Has volume: '20'
40813844-f043-48d0-9191-0b21fc47cf77 17:43:08: trace uuid; RINCON_000E587DB3C601400
<s:Body>
<u:SetVolumeResponse xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1">
</u:SetVolumeResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:43:05: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;STOPPED&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;1&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:02&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;http-get:*:audio/mpeg:*&amp;quot; duration=&amp;quot;0:00:02&amp;quot;&amp;gt;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;dc:title&amp;gt;adios_emma_emma_has_evacuated_.mp3&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.musicTrack&amp;lt;/upnp:clas...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:43:05: trace Skipping event generation for sound file https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3
40813844-f043-48d0-9191-0b21fc47cf77 17:43:03: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;PLAYING&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;1&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:02&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;http-get:*:audio/mpeg:*&amp;quot; duration=&amp;quot;0:00:02&amp;quot;&amp;gt;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;dc:title&amp;gt;adios_emma_emma_has_evacuated_.mp3&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.musicTrack&amp;lt;/upnp:clas...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:43:03: trace Skipping event generation for sound file https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3
40813844-f043-48d0-9191-0b21fc47cf77 17:43:03: trace Current status: 'playing', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:43:03: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:43:02: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;TRANSITIONING&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;1&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:02&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;http-get:*:audio/mpeg:*&amp;quot; duration=&amp;quot;0:00:02&amp;quot;&amp;gt;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;dc:title&amp;gt;adios_emma_emma_has_evacuated_.mp3&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.musicTrack&amp;lt;/upn...[TRUNCATED]
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/RCS/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;Volume channel=&quot;Master&quot; val=&quot;70&quot;/&gt;&lt;Volume channel=&quot;LF&quot; val=&quot;100&quot;/&gt;&lt;Volume channel=&quot;RF&quot; val=&quot;100&quot;/&gt;&lt;/InstanceID&gt;&lt;/Event&gt;
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:43:02: trace Has volume: '70'
40813844-f043-48d0-9191-0b21fc47cf77 17:43:02: trace uuid; RINCON_000E587DB3C601400
<s:Body>
</u:PlayResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: debug Not parsing XML message:
<s:Body>
</s:Body>
</s:Envelope>
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;STOPPED&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;9&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;hls-radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:00&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;sonos.com-http:*:audio/mpegurl:*&amp;quot;&amp;gt;x-sonosapi-stream:s24939?sid=254&amp;amp;amp;flags=8224&amp;amp;amp;sn=0&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;upnp:albumArtURI&amp;gt;/getaa?s=1&amp;amp;amp;u=x-sonosapi-stream%3as24939%3fsid%3d254%26flags%3d8224%26sn%3d0&amp;lt;/upnp:albumArtURI&amp;gt;&amp;lt;dc:title&amp;gt;x-son...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace Skipping event generation for sound file hls-radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8
<s:Body>
</s:Body>
</s:Envelope>
<s:Body>
</u:StopResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: error groovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (java.util.ArrayList) values: [[20]]
Possible solutions: round(float), round(double), find(), rint(double), find(groovy.lang.Closure), random() @line 542 (setLocalLevel)
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace setLocalLevel([20])
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace /setOtherLevels()
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace setOtherLevels([20])
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace setLevel([20])
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace sonosAction(GetVolume, RenderingControl, /MediaRenderer/RenderingControl/Control, [InstanceID:0, Channel:Master])
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace setTrack(x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0, 470 B)
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: info setTrack(x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0, null, 470 B})
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace Delaying 7000 ms before resumption
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace sonosAction(SetAVTransportURI, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, CurrentURI:https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3, CurrentURIMetaData:])
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace Setting sound track: https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace sonosAction(Play, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, Speed:1])
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: info setTrack(https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3, null, 0 B})
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace setLocalLevel(70)
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace sonosAction(Stop, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, Speed:1])
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace volume = 70
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: trace Stopping and setting level to 70
40813844-f043-48d0-9191-0b21fc47cf77 17:43:01: debug playTrackAndResume(https://s3.amazonaws.com/smartapp-media/polly-tts/salli/adios_emma_emma_has_evacuated_.mp3, 3, 70)
40813844-f043-48d0-9191-0b21fc47cf77 17:42:59: debug playTextAndResume(Adios Emma, Emma has evacuated., 70)
40813844-f043-48d0-9191-0b21fc47cf77 17:42:15: debug Not parsing XML message:
<e:property>
<LastChange>
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:42:15: trace Has volume: '20'
40813844-f043-48d0-9191-0b21fc47cf77 17:42:15: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:42:13: info Dining Room SONOS is playing BBC Radio 1
40813844-f043-48d0-9191-0b21fc47cf77 17:42:13: trace Current status: 'playing', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:42:13: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:41:41: debug Not parsing XML message:
<e:property>
<LastChange>
40813844-f043-48d0-9191-0b21fc47cf77 17:41:41: trace Skipping event generation for sound file x-rincon-mp3radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8
40813844-f043-48d0-9191-0b21fc47cf77 17:41:41: trace Current status: 'stopped', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:41:41: trace uuid; RINCON_000E587DB3C601400
<s:Body>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:41:40: debug Not parsing XML message:
<s:Body>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:41:39: debug Not parsing XML message:
<s:Body>
<u:GetVolumeResponse xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1">
<CurrentVolume>
42
</CurrentVolume>
</u:GetVolumeResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:41:39: trace Extracting current volume
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/RCS/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;Volume channel=&quot;Master&quot; val=&quot;42&quot;/&gt;&lt;Volume channel=&quot;LF&quot; val=&quot;100&quot;/&gt;&lt;Volume channel=&quot;RF&quot; val=&quot;100&quot;/&gt;&lt;/InstanceID&gt;&lt;/Event&gt;
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:41:39: trace Has volume: '42'
40813844-f043-48d0-9191-0b21fc47cf77 17:41:39: trace uuid; RINCON_000E587DB3C601400
<s:Body>
</u:StopResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:41:36: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;STOPPED&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;1&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/f753208dc2788c84061367f1f73c263b462b539c.mp3&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:02&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;http-get:*:audio/mpeg:*&amp;quot; duration=&amp;quot;0:00:02&amp;quot;&amp;gt;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/f753208dc2788c84061367f1f73c263b462b539c.mp3&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;dc:title&amp;gt;f753208dc2788c84061367f1f73c263b462b539c.mp3&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.mu...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:41:36: trace Current status: 'stopped', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:41:34: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;PLAYING&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;1&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/f753208dc2788c84061367f1f73c263b462b539c.mp3&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:02&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;http-get:*:audio/mpeg:*&amp;quot; duration=&amp;quot;0:00:02&amp;quot;&amp;gt;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/f753208dc2788c84061367f1f73c263b462b539c.mp3&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;dc:title&amp;gt;f753208dc2788c84061367f1f73c263b462b539c.mp3&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.mu...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:41:34: trace Skipping event generation for sound file https://s3.amazonaws.com/smartapp-media/polly-tts/salli/f753208dc2788c84061367f1f73c263b462b539c.mp3
<e:property>
<LastChange>
40813844-f043-48d0-9191-0b21fc47cf77 17:41:34: trace Current status: 'playing', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:41:34: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: debug Not parsing XML message:
<s:Body>
</u:PlayResponse>
</s:Body>
</s:Envelope>
<s:Body>
</s:Body>
</s:Envelope>
<s:Body>
<CurrentVolume>
70
</CurrentVolume>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace Extracting current volume
<e:property>
<LastChange>
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace Has volume: '70'
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace uuid; RINCON_000E587DB3C601400
<s:Body>
</s:Body>
</s:Envelope>
<s:Body>
</u:StopResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: error groovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (java.util.ArrayList) values: [[42]]
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace setLocalLevel([42])
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace /setOtherLevels()
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace setOtherLevels([42])
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace setLevel([42])
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace sonosAction(SetAVTransportURI, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, CurrentURI:x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0, CurrentURIMetaData:<DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="-1" parentID="-1" restricted="true"><dc:title>BBC Radio 1</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/">SA_RINCON65031_</desc></item></DIDL-Lite>])
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: info setTrack(x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0, null, 470 B})
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace Restoring track x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace sonosAction(GetVolume, RenderingControl, /MediaRenderer/RenderingControl/Control, [InstanceID:0, Channel:Master])
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace volume = 42
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace sonosAction(Stop, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, Speed:1])
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace Delaying 7000 ms before resumption
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace sonosAction(SetVolume, RenderingControl, /MediaRenderer/RenderingControl/Control, [InstanceID:0, Channel:Master, DesiredVolume:42])
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace setLocalLevel(42)
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace sonosAction(SetAVTransportURI, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, CurrentURI:https://s3.amazonaws.com/smartapp-media/polly-tts/salli/f753208dc2788c84061367f1f73c263b462b539c.mp3, CurrentURIMetaData:])
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace Setting sound track: https://s3.amazonaws.com/smartapp-media/polly-tts/salli/f753208dc2788c84061367f1f73c263b462b539c.mp3
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace Restoring volume to 42
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace sonosAction(Play, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, Speed:1])
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: info setTrack(https://s3.amazonaws.com/smartapp-media/polly-tts/salli/f753208dc2788c84061367f1f73c263b462b539c.mp3, null, 0 B})
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace setLocalLevel(70)
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace sonosAction(SetVolume, RenderingControl, /MediaRenderer/RenderingControl/Control, [InstanceID:0, Channel:Master, DesiredVolume:70])
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace volume = 70
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: trace Stopping and setting level to 70
40813844-f043-48d0-9191-0b21fc47cf77 17:41:32: debug playTrackAndResume(https://s3.amazonaws.com/smartapp-media/polly-tts/salli/f753208dc2788c84061367f1f73c263b462b539c.mp3, 3, 70)
40813844-f043-48d0-9191-0b21fc47cf77 17:41:31: debug playTextAndResume(How goes it Emma, Emma is showing up., 70)
this is with them grouped, it worked this time apart on both arrive and leave. It also changed the volume correctly, did you change anything on the latest rev?
40813844-f043-48d0-9191-0b21fc47cf77 17:46:43: info Dining Room SONOS is playing BBC Radio 1
40813844-f043-48d0-9191-0b21fc47cf77 17:46:43: trace Current status: 'playing', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:46:43: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:46:42: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;TRANSITIONING&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;9&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;hls-radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:00&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;sonos.com-http:*:audio/mpegurl:*&amp;quot;&amp;gt;x-sonosapi-stream:s24939?sid=254&amp;amp;amp;flags=8224&amp;amp;amp;sn=0&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;upnp:albumArtURI&amp;gt;/getaa?s=1&amp;amp;amp;u=x-sonosapi-stream%3as24939%3fsid%3d254%26flags%3d8224%26sn%3d0&amp;lt;/upnp:albumArtURI&amp;gt;&amp;lt;dc:title&amp;gt...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:46:42: trace Skipping event generation for sound file hls-radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8
40813844-f043-48d0-9191-0b21fc47cf77 17:46:41: debug Not parsing XML message:
<e:property>
<LastChange>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:41: trace Skipping event generation for sound file hls-radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8
40813844-f043-48d0-9191-0b21fc47cf77 17:46:41: trace uuid; RINCON_000E587DB3C601400
<e:property>
<LastChange>
<s:Body>
</u:PlayResponse>
</s:Body>
</s:Envelope>
<e:property>
<LastChange>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:41: trace Skipping event generation for sound file x-rincon-mp3radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8
<s:Body>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:39: debug Not parsing XML message:
<s:Body>
<CurrentVolume>
14
</CurrentVolume>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:39: trace Extracting current volume
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/RCS/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;Volume channel=&quot;Master&quot; val=&quot;14&quot;/&gt;&lt;Volume channel=&quot;LF&quot; val=&quot;100&quot;/&gt;&lt;Volume channel=&quot;RF&quot; val=&quot;100&quot;/&gt;&lt;/InstanceID&gt;&lt;/Event&gt;
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:39: trace Has volume: '14'
40813844-f043-48d0-9191-0b21fc47cf77 17:46:39: trace uuid; RINCON_000E587DB3C601400
<s:Body>
</s:Body>
</s:Envelope>
<s:Body>
</u:StopResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:36: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;STOPPED&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;1&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:02&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;http-get:*:audio/mpeg:*&amp;quot; duration=&amp;quot;0:00:02&amp;quot;&amp;gt;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;dc:title&amp;gt;c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.mu...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:46:36: trace Skipping event generation for sound file https://s3.amazonaws.com/smartapp-media/polly-tts/salli/c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3
40813844-f043-48d0-9191-0b21fc47cf77 17:46:36: trace Current status: 'stopped', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:46:36: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:46:33: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;PLAYING&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;1&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:02&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;http-get:*:audio/mpeg:*&amp;quot; duration=&amp;quot;0:00:02&amp;quot;&amp;gt;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;dc:title&amp;gt;c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.mu...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:46:33: trace Skipping event generation for sound file https://s3.amazonaws.com/smartapp-media/polly-tts/salli/c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3
40813844-f043-48d0-9191-0b21fc47cf77 17:46:33: trace Current status: 'playing', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:46:33: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: debug Not parsing XML message:
<s:Body>
</u:PlayResponse>
</s:Body>
</s:Envelope>
<e:property>
<LastChange>
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace Has volume: '70'
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace uuid; RINCON_000E587DB3C601400
<s:Body>
</s:Body>
</s:Envelope>
<e:property>
<LastChange>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace Skipping event generation for sound file hls-radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace Current status: 'stopped', coordinator: ''
<s:Body>
<CurrentVolume>
70
</CurrentVolume>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace Extracting current volume
<s:Body>
</s:Body>
</s:Envelope>
<s:Body>
</u:StopResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: error groovy.lang.MissingMethodException: No signature of method: java.util.ArrayList.div() is applicable for argument types: (java.lang.Integer) values: [14]
Possible solutions: min(), get(int), get(int), min(groovy.lang.Closure), drop(int), min(java.util.Comparator) @line 574 (childLevel)
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace setting levels of coordinated players
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace setOtherLevels([14])
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace setLevel([14])
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace sonosAction(SetAVTransportURI, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, CurrentURI:x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0, CurrentURIMetaData:<DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="-1" parentID="-1" restricted="true"><dc:title>BBC Radio 1</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/">SA_RINCON65031_</desc></item></DIDL-Lite>])
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace sonosAction(SetVolume, RenderingControl, /MediaRenderer/RenderingControl/Control, [InstanceID:0, Channel:Master, DesiredVolume:14])
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace sonosAction(GetVolume, RenderingControl, /MediaRenderer/RenderingControl/Control, [InstanceID:0, Channel:Master])
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace setTrack(x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0, 470 B)
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: info setTrack(x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0, null, 470 B})
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace Delaying 7000 ms before resumption
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace Restoring track x-sonosapi-stream:s24939?sid=254&flags=8224&sn=0
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace Setting sound track: https://s3.amazonaws.com/smartapp-media/polly-tts/salli/c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace sonosAction(Play, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, Speed:1])
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace Restoring volume to 14
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace sonosAction(SetVolume, RenderingControl, /MediaRenderer/RenderingControl/Control, [InstanceID:0, Channel:Master, DesiredVolume:70])
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace sonosAction(SetAVTransportURI, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, CurrentURI:https://s3.amazonaws.com/smartapp-media/polly-tts/salli/c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3, CurrentURIMetaData:])
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace volume = 70
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: info setTrack(https://s3.amazonaws.com/smartapp-media/polly-tts/salli/c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3, null, 0 B})
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace setLocalLevel(70)
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace sonosAction(Stop, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, Speed:1])
Had to spread it over 2 posts this is the 1st
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: trace Stopping and setting level to 70
40813844-f043-48d0-9191-0b21fc47cf77 17:46:32: debug playTrackAndResume(https://s3.amazonaws.com/smartapp-media/polly-tts/salli/c4cf368ed4c8f696bee25ba6e7464c9d2dfba62e.mp3, 3, 70)
40813844-f043-48d0-9191-0b21fc47cf77 17:46:31: debug playTextAndResume(Arrivederci Emma, Emma has high tailed it., 70)
40813844-f043-48d0-9191-0b21fc47cf77 17:46:06: debug Not parsing XML message:
<e:property>
<LastChange>
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:06: trace Has volume: '14'
40813844-f043-48d0-9191-0b21fc47cf77 17:46:06: trace uuid; RINCON_000E587DB3C601400
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/RCS/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;Volume channel=&quot;Master&quot; val=&quot;18&quot;/&gt;&lt;Volume channel=&quot;LF&quot; val=&quot;100&quot;/&gt;&lt;Volume channel=&quot;RF&quot; val=&quot;100&quot;/&gt;&lt;/InstanceID&gt;&lt;/Event&gt;
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:06: trace Has volume: '18'
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/RCS/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;Volume channel=&quot;Master&quot; val=&quot;46&quot;/&gt;&lt;Volume channel=&quot;LF&quot; val=&quot;100&quot;/&gt;&lt;Volume channel=&quot;RF&quot; val=&quot;100&quot;/&gt;&lt;/InstanceID&gt;&lt;/Event&gt;
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:46:06: trace Has volume: '46'
40813844-f043-48d0-9191-0b21fc47cf77 17:45:42: info Dining Room SONOS is playing BBC Radio 1
40813844-f043-48d0-9191-0b21fc47cf77 17:45:42: trace Current status: 'playing', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:45:42: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:45:41: debug Not parsing XML message:
<e:property>
<LastChange>
40813844-f043-48d0-9191-0b21fc47cf77 17:45:41: trace Skipping event generation for sound file hls-radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8
40813844-f043-48d0-9191-0b21fc47cf77 17:45:41: trace uuid; RINCON_000E587DB3C601400
<s:Body>
</u:PlayResponse>
</s:Body>
</s:Envelope>
<e:property>
<LastChange>
40813844-f043-48d0-9191-0b21fc47cf77 17:45:40: debug Not parsing XML message:
<e:property>
<LastChange>
<s:Body>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:45:39: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/RCS/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;Volume channel=&quot;Master&quot; val=&quot;61&quot;/&gt;&lt;Volume channel=&quot;LF&quot; val=&quot;100&quot;/&gt;&lt;Volume channel=&quot;RF&quot; val=&quot;100&quot;/&gt;&lt;/InstanceID&gt;&lt;/Event&gt;
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:45:39: trace Has volume: '61'
40813844-f043-48d0-9191-0b21fc47cf77 17:45:39: trace uuid; RINCON_000E587DB3C601400
<s:Body>
</s:Body>
</s:Envelope>
<s:Body>
<CurrentVolume>
61
</CurrentVolume>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:45:39: trace Extracting current volume
<s:Body>
</u:StopResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:45:38: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;STOPPED&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;1&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/ff9687da8907873891a37f99b021c1ea9945e425.mp3&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:02&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;http-get:*:audio/mpeg:*&amp;quot; duration=&amp;quot;0:00:02&amp;quot;&amp;gt;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/ff9687da8907873891a37f99b021c1ea9945e425.mp3&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;dc:title&amp;gt;ff9687da8907873891a37f99b021c1ea9945e425.mp3&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.mu...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:45:38: trace Skipping event generation for sound file https://s3.amazonaws.com/smartapp-media/polly-tts/salli/ff9687da8907873891a37f99b021c1ea9945e425.mp3
40813844-f043-48d0-9191-0b21fc47cf77 17:45:38: trace Current status: 'stopped', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:45:38: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:45:35: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;PLAYING&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;1&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/ff9687da8907873891a37f99b021c1ea9945e425.mp3&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:02&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;http-get:*:audio/mpeg:*&amp;quot; duration=&amp;quot;0:00:02&amp;quot;&amp;gt;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/ff9687da8907873891a37f99b021c1ea9945e425.mp3&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;dc:title&amp;gt;ff9687da8907873891a37f99b021c1ea9945e425.mp3&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.mu...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:45:35: trace Skipping event generation for sound file https://s3.amazonaws.com/smartapp-media/polly-tts/salli/ff9687da8907873891a37f99b021c1ea9945e425.mp3
40813844-f043-48d0-9191-0b21fc47cf77 17:45:35: trace Current status: 'playing', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:45:35: trace uuid; RINCON_000E587DB3C601400
40813844-f043-48d0-9191-0b21fc47cf77 17:45:34: debug Not parsing XML message:
<e:property>
<LastChange>
&lt;Event xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/AVT/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;&lt;InstanceID val=&quot;0&quot;&gt;&lt;TransportState val=&quot;TRANSITIONING&quot;/&gt;&lt;CurrentPlayMode val=&quot;NORMAL&quot;/&gt;&lt;CurrentCrossfadeMode val=&quot;0&quot;/&gt;&lt;NumberOfTracks val=&quot;1&quot;/&gt;&lt;CurrentTrack val=&quot;1&quot;/&gt;&lt;CurrentSection val=&quot;0&quot;/&gt;&lt;CurrentTrackURI val=&quot;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/ff9687da8907873891a37f99b021c1ea9945e425.mp3&quot;/&gt;&lt;CurrentTrackDuration val=&quot;0:00:02&quot;/&gt;&lt;CurrentTrackMetaData val=&quot;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;-1&amp;quot; parentID=&amp;quot;-1&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;res protocolInfo=&amp;quot;http-get:*:audio/mpeg:*&amp;quot; duration=&amp;quot;0:00:02&amp;quot;&amp;gt;https://s3.amazonaws.com/smartapp-media/polly-tts/salli/ff9687da8907873891a37f99b021c1ea9945e425.mp3&amp;lt;/res&amp;gt;&amp;lt;r:streamContent&amp;gt;&amp;lt;/r:streamContent&amp;gt;&amp;lt;r:radioShowMd&amp;gt;&amp;lt;/r:radioShowMd&amp;gt;&amp;lt;dc:title&amp;gt;ff9687da8907873891a37f99b021c1ea9945e425.mp3&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioI...[TRUNCATED]
40813844-f043-48d0-9191-0b21fc47cf77 17:45:34: trace Skipping event generation for sound file https://s3.amazonaws.com/smartapp-media/polly-tts/salli/ff9687da8907873891a37f99b021c1ea9945e425.mp3
40813844-f043-48d0-9191-0b21fc47cf77 17:45:34: trace uuid; RINCON_000E587DB3C601400
<e:property>
<LastChange>
</LastChange>
</e:property>
</e:propertyset>
40813844-f043-48d0-9191-0b21fc47cf77 17:45:34: trace Has volume: '70'
<s:Body>
</u:PlayResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:45:32: debug Not parsing XML message:
<s:Body>
</s:Body>
</s:Envelope>
<s:Body>
<CurrentVolume>
70
</CurrentVolume>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:45:32: trace Extracting current volume
<e:property>
<LastChange>
40813844-f043-48d0-9191-0b21fc47cf77 17:45:32: trace Skipping event generation for sound file hls-radio://http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/llnw/bbc_radio_one.m3u8
40813844-f043-48d0-9191-0b21fc47cf77 17:45:32: trace Current status: 'stopped', coordinator: ''
40813844-f043-48d0-9191-0b21fc47cf77 17:45:32: trace uuid; RINCON_000E587DB3C601400
<s:Body>
</s:Body>
</s:Envelope>
<s:Body>
</u:StopResponse>
</s:Body>
</s:Envelope>
40813844-f043-48d0-9191-0b21fc47cf77 17:45:32: error groovy.lang.MissingMethodException: No signature of method: java.util.ArrayList.div() is applicable for argument types: (java.lang.Integer) values: [61]
Possible solutions: min(), get(int), get(int), drop(int), drop(int), is(java.lang.Object) @line 574 (childLevel)
40813844-f043-48d0-9191-0b21fc47cf77 17:45:32: trace setting levels of coordinated players
not like today but probably 10 days ago … changed how level is set / restored and mute.
I updated it about 10 days ago but i was on my IDE today and the GITHUB integration said my version was not uptodate.
Well I must have had the old one, it fixed it
on another note my HE hub arrived today
is the code the same for hubitat?
I have a similar presence web-core script but use motion detect because I don’t have a contact sensor. Would be great to just have it all included in the room manager. I have a motion detection that points at my front door.
