I’ve got a piston set up to test if my garage door is open (and one to test if it’s closed). If the piston to open detects that the garage door is closed it will open it and if the piston to close detects that it is open it will close it. I’m executing that piston using Ask Alexa macro triggers. Basically I just tell Alexa to tell smartthings to open my garage door and then it runs the Open Garage Piston. Vice versa for the Close Garage Piston.
Everything works to open and close the garage door using the Ask Alexa skill. The problem is that when I close the door manually the “Open Garage Door” “If statement” is still running and it will open my garage door again.
I need to stop the execution of the piston after it has run once and not run it again until I invoke it again using Ask Alexa. Anybody have any ideas?
This is my setup for the Open:
