To be clear, I’m not sure if the problem is exclusive to Webcore, so I’m trying different things to nail down the problem. I have a larger piston that makes comments based on triggers. It fires successfully about 50% of the time. I took this smaller part out, and made a new, smaller piston. I can fire it twice, but on the third try, it doesn’t even run the first command (turn virtual switch off). These are commands used to change the voice of Alexa through ES. Normally, the messages would be sent as dynamic strings, but the voices aspect requires them sent as a value (as far as I have been able to ascertain).
I use the setAlarmVolume to let my central speaking piston know which Echoes to speak from. Many times, I will see the ring turn blue, indicating the Volume change, but no speech is made.
In another (and larger) piston, I was unable to add any more Condition statements or Actions. I thought the issue was with my piston. However, when I imported someone else’s to make some changes. Webcore still wouldn’t let me make changes. When I tried to drag-and-drop the lines instead, the lines would disappear when I dropped them. I’ve tried clearing the Webcore cache, but I’m still having issues. It feels like Webcore is slowly breaking down on me. Am I being throttled? Should I reinstall WC?
Any suggestions would be helpful.
P.S. on an interesting note, when I use regular speaking commands, they show up in my Alexa history. when I do these new voice commands with ssml, they don’t show up in my Alexa history.
02/01/2020, 10:36:59 +344ms
+2ms ╔Received event [An Unused Switch].switch = on with a delay of 308ms
+122ms ║RunTime Analysis CS > 25ms > PS > 62ms > PE > 35ms > CE
+125ms ║Runtime (53481 bytes) successfully initialized in 62ms (v0.3.110.20191009) (123ms)
+132ms ║║Comparison (enum) on changes_to (string) on = false (0ms)
+134ms ║║Cancelling condition #99’s schedules…
+135ms ║║Condition #99 evaluated false (5ms)
+136ms ║║Cancelling condition #98’s schedules…
+136ms ║║Condition group #98 evaluated false (state changed) (7ms)
+138ms ║╚Execution stage complete. (13ms)
+139ms ╚Event processed successfully (139ms)
02/01/2020, 10:36:49 +360ms
+2ms ╔Received event [An Unused Switch].switch = on with a delay of 334ms
+117ms ║RunTime Analysis CS > 23ms > PS > 63ms > PE > 31ms > CE
+120ms ║Runtime (53497 bytes) successfully initialized in 63ms (v0.3.110.20191009) (117ms)
+128ms ║║Comparison (enum) on changes_to (string) on = true (0ms)
+129ms ║║Cancelling condition #99’s schedules…
+130ms ║║Condition #99 evaluated true (5ms)
+131ms ║║Cancelling condition #98’s schedules…
+132ms ║║Condition group #98 evaluated true (state changed) (7ms)
+134ms ║║Cancelling statement #322’s schedules…
+148ms ║║Executed physical command [An Unused Switch].off() (11ms)
+149ms ║║Executed [An Unused Switch].off (13ms)
+151ms ║║Cancelling statement #76’s schedules…
+160ms ║║Executed virtual command setVariable (3ms)
+165ms ║║Executed virtual command setVariable (3ms)
+170ms ║║Calculating (string) <voice name=" + (string) Salli >> (string) <voice name=“Salli
+173ms ║║Calculating (string) Who the hell unlocked the back door? >> (string) Who the hell unlocked the back door?
+176ms ║║Executed virtual command setVariable (0ms)
+179ms ║║Executed virtual command setVariable (1ms)
+181ms ║║Cancelling statement #100’s schedules…
+228ms ║║Executed physical command [Front Door Light].setStatusLed([6, 3, 0]) (38ms)
+229ms ║║Executed [Front Door Light].setStatusLed (40ms)
+250ms ║║Executed physical command [Master Patio Switch].setStatusLed([6, 3, 0]) (18ms)
+251ms ║║Executed [Master Patio Switch].setStatusLed (20ms)
+254ms ║║Cancelling statement #313’s schedules…
+534ms ║║Executed physical command [Echo - Computer Echo].setAlarmVolume([99]) (273ms)
+535ms ║║Executed [Echo - Computer Echo].setAlarmVolume (275ms)
+801ms ║║Executed physical command [Echo - Living Room Echo].setAlarmVolume([99]) (261ms)
+802ms ║║Executed [Echo - Living Room Echo].setAlarmVolume (263ms)
+939ms ║║Comparison (dynamic) 61 is_less_than (integer) 70 = true (2ms)
+942ms ║║Cancelling statement #284’s schedules…
+947ms ║║Executed virtual command setVariable (3ms)
+953ms ║║Calculating (string) The back door is closed and locked + (string) , I hope you wore a jacket >> (string) The back door is closed and locked, I hope you wore a jacket
+959ms ║║Executed virtual command setVariable (4ms)
+966ms ║║Calculating (string) <voice name=” + (string) Salli >> (string) <voice name=“Salli
+970ms ║║Calculating (string) >> (string)
+973ms ║║Calculating (string) + (string) The back door is closed and locked, I hope you wore a jacket >> (string) The back door is closed and locked, I hope you wore a jacket
+975ms ║║Calculating (string) The back door is closed and locked, I hope you wore a jacket + (string) >> (string) The back door is closed and locked, I hope you wore a jacket
+978ms ║║Executed virtual command setVariable (1ms)
+982ms ║║Executed virtual command setVariable (1ms)
+983ms ║║Condition #283 evaluated true (178ms)
+984ms ║║Condition group #281 evaluated true (state did not change) (180ms)
+986ms ║╚Execution stage complete. (866ms)
+987ms ╚Event processed successfully (987ms)
02/01/2020, 10:36:36 +737ms
+1ms ╔Received event [An Unused Switch].switch = off with a delay of 165ms
+9859ms ║RunTime Analysis CS > 28ms > PS > 9805ms > PE > 27ms > CE
+9860ms ║Piston waited at a semaphore for 9766ms
+9863ms ║Runtime (53549 bytes) successfully initialized in 9805ms (v0.3.110.20191009) (9862ms)
+9864ms ║╔Execution stage started
+9870ms ║║Comparison (enum) off changes_to (string) on = false (0ms)
+9872ms ║║Cancelling condition #99’s schedules…
+9873ms ║║Condition #99 evaluated false (4ms)
+9874ms ║║Cancelling condition #98’s schedules…
+9874ms ║║Condition group #98 evaluated false (state changed) (7ms)
+9876ms ║╚Execution stage complete. (13ms)
+9877ms ╚Event processed successfully (9877ms)
02/01/2020, 10:36:36 +398ms
+1ms ╔Received event [An Unused Switch].switch = on with a delay of 218ms
+84ms ║RunTime Analysis CS > 17ms > PS > 41ms > PE > 26ms > CE
+87ms ║Runtime (53471 bytes) successfully initialized in 41ms (v0.3.110.20191009) (86ms)
+95ms ║║Comparison (enum) on changes_to (string) on = true (0ms)
+96ms ║║Cancelling condition #99’s schedules…
+97ms ║║Condition #99 evaluated true (5ms)
+98ms ║║Cancelling condition #98’s schedules…
+99ms ║║Condition group #98 evaluated true (state changed) (7ms)
+101ms ║║Cancelling statement #322’s schedules…
+109ms ║║Executed physical command [An Unused Switch].off() (6ms)
+110ms ║║Executed [An Unused Switch].off (7ms)
+112ms ║║Cancelling statement #76’s schedules…
+120ms ║║Executed virtual command setVariable (2ms)
+125ms ║║Executed virtual command setVariable (2ms)
+131ms ║║Calculating (string) <voice name=” + (string) Liv >> (string) <voice name=“Liv
+133ms ║║Calculating (string) Who the hell unlocked the back door? >> (string) Who the hell unlocked the back door?
+136ms ║║Executed virtual command setVariable (1ms)
+139ms ║║Executed virtual command setVariable (1ms)
+142ms ║║Cancelling statement #100’s schedules…
+363ms ║║Executed physical command [Front Door Light].setStatusLed([6, 3, 0]) (215ms)
+364ms ║║Executed [Front Door Light].setStatusLed (216ms)
+379ms ║║Executed physical command [Master Patio Switch].setStatusLed([6, 3, 0]) (13ms)
+380ms ║║Executed [Master Patio Switch].setStatusLed (13ms)
+382ms ║║Cancelling statement #313’s schedules…
+730ms ║║Executed physical command [Echo - Computer Echo].setAlarmVolume([99]) (342ms)
+731ms ║║Executed [Echo - Computer Echo].setAlarmVolume (344ms)
+995ms ║║Executed physical command [Echo - Living Room Echo].setAlarmVolume([99]) (259ms)
+996ms ║║Executed [Echo - Living Room Echo].setAlarmVolume (261ms)
+1130ms ║║Comparison (dynamic) 61 is_less_than (integer) 70 = true (1ms)
+1132ms ║║Cancelling statement #284’s schedules…
+1138ms ║║Executed virtual command setVariable (3ms)
+1149ms ║║Calculating (string) Did you know it’s + (string) 61 >> (string) Did you know it’s 61
+1152ms ║║Calculating (string) Did you know it’s 61 + (string) degrees outside? >> (string) Did you know it’s 61 degrees outside?
+1153ms ║║Calculating (string) The back door is closed and locked + (string) Did you know it’s 61 degrees outside? >> (string) The back door is closed and locked Did you know it’s 61 degrees outside?
+1158ms ║║Executed virtual command setVariable (3ms)
+1166ms ║║Calculating (string) <voice name=” + (string) Liv >> (string) <voice name="Liv
+1169ms ║║Calculating (string) >> (string)
+1172ms ║║Calculating (string) + (string) The back door is closed and locked Did you know it’s 61 degrees outside? >> (string) The back door is closed and locked Did you know it’s 61 degrees outside?
+1175ms ║║Calculating (string) The back door is closed and locked Did you know it’s 61 degrees outside? + (string) >> (string) The back door is closed and locked Did you know it’s 61 degrees outside?
+1178ms ║║Executed virtual command setVariable (1ms)
+1182ms ║║Executed virtual command setVariable (1ms)
+1183ms ║║Condition #283 evaluated true (185ms)
+1184ms ║║Condition group #281 evaluated true (state did not change) (186ms)
+1186ms ║╚Execution stage complete. (1099ms)
+1187ms ╚Event processed successfully (1187ms)
