Is it possible to use the Set Level option in webcore with a duration setting? On my Hubitat device, I can set my light level and specific a duration. When I do that I get a nice smooth transition when changing to the new level. I’ve tried the fade level opition in Webcore and its not the same, its chunky not smooth.
Set Level with Duration
ian_boje
Funny, I asked the same question here: Hardware fade level
Did you ever find a way to do this? I considered looking at the webcore code a bit to see what it would take to add it, but I couldn’t understand it.
Perhaps there’s a way to issue commands to rule machine and let rule machine issue the hardware fade commands.
