hello everyone, im coming over from stringify and just cant seem to get anything working the way i would like. This piston does not trigger at all and i think it has to do with the temp rquest
when the outside temp is equal to or lower than the temp of the thermostat, if the lamp is off-turn it on and flash it a few times. if the lamp is already on and being used, turn the color to blue. i would then like the thermostat to turn off so we can open the windows
nothing is happenng. i tried to simplify it and have just the "time is after 5 pm " portion and it still didnt fire.
4) Post a Green Snapshot of the piston!)
(UPLOAD YOUR IMAGE HERE)
5/12/2019, 11:22:46 AM +130ms
+1ms â•”Received event [Home].test = 1557685366129 with a delay of 0ms
+189ms â•‘RunTime Analysis CS > 26ms > PS > 142ms > PE > 22ms > CE
+193ms â•‘Runtime (38654 bytes) successfully initialized in 142ms (v0.3.10a.20190223) (190ms)
+195ms â•‘â•”Execution stage started
+219ms â•‘â•‘Comparison (time) 40966334 is_after (time) 61200000 = false (12ms)
+222ms â•‘â•‘Condition #1 evaluated false (18ms)
+223ms â•‘â•‘Condition group #null evaluated false (state did not change) (21ms)
+225ms â•‘â•‘Piston execution aborted due to restrictions in effect
+238ms â•‘â•‘Comparison (string) ONLINE is (string) Off = false (2ms)
+255ms â•‘â•‘Comparison (string) ONLINE is (string) on = false (3ms)
+269ms ║╚Execution stage complete. (75ms)
+271ms ╚Event processed successfully (271ms)
Clear
