Since about 2 days ago one of my pistons that worked fine for over a year started not working properly and I’m getting this error
+304ms ║Error while executing physical command Kitchen SkyLight.off([]): org.hibernate.LazyInitializationException: could not initialize proxy - no Session
Can somebody please help me to figure out what it means?
Thanks for reply !
Yes, no problem controlling using ST
Just noticed that another light and fan started doing the same thing
6/1/2019, 9:06:48 AM +115ms
+207ms ║Error while executing physical command Work Shop Light.off([]): org.hibernate.LazyInitializationException: could not initialize proxy - no Session
6/1/2019, 12:33:24 PM +103ms
+151ms ║Error while executing physical command Bath Basement Fan.off([]): org.hibernate.LazyInitializationException: could not initialize proxy - no Session
problem is always the OFF command, they turn ON but never switch OFF
Changing the Device handler to generic Z-Wave Switch does fix the problem, since it’s locally executed but you lose all the advanced features on the switch
If someone can shed some light on this that would be great.
Thanks
Got it!
Strangely enough the control using ST app is not affected.
Also the device handler from the same dev for dimmer working fine …Hope I didn’t jinx it
Thank you
