Using a SWITCHBOT to turn aircon on and off at certain temps
when temp rises above x PRESS button IF button has been pressed in last x minutes and temp drops below y press button again
I cant finish the piston successfully
This is an interesting one I am using a SWITCHBOT (device that presses a button on a command from IFTTT) to try to turn ON aircon and then off again at certain tempsâŚ
Now my aircon wall control on/off is the SAME button and it cant be known if its off or on (if that makes sense)
So I need a piston that says
if temp rises above x press the button
if temp drops below y press button again BUT only if the button was pressed in the last z minutes - which means the aircon is already ON (other wise the temp DROP press could actually turn it ON if it hadnât already been pressed )
I really dont know how to progress this as you can see above Iâm stuck LOL
if anyone has any brainwaves (or a more elegant solution ) I would be grateful
Thanks again !
Bill P
