There seems to be no rhyme or reason to when this works and when it does not. I added a wait (5 or 10 seconds) after the web request, and now it returns null for http status code regardless of if it is successful or not. I have nothing but time today, is there a webcore documentation I can dive into?
3/27/2020, 11:24:03 AM +71ms
+1ms ╔Received event [Evans St].time = 1585333443665 with a delay of -595ms
+682ms ║RunTime Analysis CS > 540ms > PS > 86ms > PE > 56ms > CE
+685ms ║Runtime (41965 bytes) successfully initialized in 86ms (v0.3.110.20191009) (682ms)
+686ms ║╔Execution stage started
+701ms ║║Cancelling statement #28's schedules...
+718ms ║║Sending internal web request to: 10.1.100.25:8086/query
+722ms ║║Executed virtual command [Plant - Lime Tree].httpRequest (9ms)
+723ms ║║Requesting a wake up for Fri, Mar 27 2020 @ 11:24:23 AM PDT (in 20.0s)
+731ms ║╚Execution stage complete. (45ms)
+733ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:24:23 AM PDT (in 19.992s), with 1 more job pending
+742ms ╚Event processed successfully (742ms)
3/27/2020, 11:23:31 AM +198ms
+0ms ╔Received event [Evans St].wc_async_reply = httpRequest with a delay of 0ms
+10246ms ║RunTime Analysis CS > 20ms > PS > 10068ms > PE > 158ms > CE
+10247ms ║Piston waited at a semaphore for 10013ms
+10250ms ║Runtime (42050 bytes) successfully initialized in 10068ms (v0.3.110.20191009) (10249ms)
+10251ms ║╔Execution stage started
+10252ms ║╚Execution stage complete. (1ms)
+10253ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:24:03 AM PDT (in 22.215s)
+10264ms ╚Event processed successfully (10264ms)
3/27/2020, 11:23:31 AM +118ms
+1ms ╔Received event [Evans St].time = 1585333412460 with a delay of -1342ms
+143ms ║RunTime Analysis CS > 30ms > PS > 50ms > PE > 62ms > CE
+146ms ║Runtime (41965 bytes) successfully initialized in 50ms (v0.3.110.20191009) (143ms)
+147ms ║╔Execution stage started
+164ms ║║null
+166ms ║║Executed virtual command [Plant - Lime Tree].log (2ms)
+173ms ║║[:]
+174ms ║║Executed virtual command [Plant - Lime Tree].log (2ms)
+178ms ║║Error parsing JSON data [:]
+179ms ║║Executed virtual command [Plant - Lime Tree].parseJson (2ms)
+183ms ║║Error retrieving JSON data part null
+188ms ║║Executed virtual command [Plant - Lime Tree].setVariable (3ms)
+192ms ║║Error retrieving JSON data part null
+198ms ║║Executed virtual command [Plant - Lime Tree].setVariable (3ms)
+201ms ║║Error retrieving JSON data part null
+206ms ║║Executed virtual command [Plant - Lime Tree].setVariable (3ms)
+210ms ║║Error retrieving JSON data part null
+215ms ║║Executed virtual command [Plant - Lime Tree].setVariable (3ms)
+220ms ║║Error retrieving JSON data part null
+225ms ║║Calculating (decimal) 0.0 * (decimal) 1.8 >> (decimal) 0.0
+229ms ║║Calculating (decimal) 0.0 + (decimal) 32.0 >> (decimal) 32.0
+234ms ║║Executed virtual command [Plant - Lime Tree].setVariable (3ms)
+273ms ║║Executed physical command [Plant - Lime Tree].getBattery([0]) (35ms)
+274ms ║║Executed [Plant - Lime Tree].getBattery (37ms)
+295ms ║║Executed physical command [Plant - Lime Tree].changeMoisture([0]) (18ms)
+296ms ║║Executed [Plant - Lime Tree].changeMoisture (19ms)
+315ms ║║Executed physical command [Plant - Lime Tree].changeFert([0]) (16ms)
+316ms ║║Executed [Plant - Lime Tree].changeFert (18ms)
+338ms ║║Executed physical command [Plant - Lime Tree].changeLight([0]) (18ms)
+339ms ║║Executed [Plant - Lime Tree].changeLight (20ms)
+360ms ║║Executed physical command [Plant - Lime Tree].changeTemp([32.0]) (18ms)
+362ms ║║Executed [Plant - Lime Tree].changeTemp (20ms)
+368ms ║╚Execution stage complete. (221ms)
+369ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:24:03 AM PDT (in 32.178s)
+378ms ╚Event processed successfully (377ms)
3/27/2020, 11:23:22 AM +266ms
+1ms ╔Received event [Evans St].time = 1585333403251 with a delay of -985ms
+174ms ║RunTime Analysis CS > 43ms > PS > 87ms > PE > 44ms > CE
+177ms ║Runtime (41964 bytes) successfully initialized in 87ms (v0.3.110.20191009) (176ms)
+178ms ║╔Execution stage started
+192ms ║║Executed virtual command [Plant - Lime Tree].wait (0ms)
+193ms ║║Requesting a wake up for Fri, Mar 27 2020 @ 11:23:32 AM PDT (in 10.0s)
+200ms ║╚Execution stage complete. (23ms)
+203ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:23:32 AM PDT (in 9.992s), with 1 more job pending
+211ms ╚Event processed successfully (211ms)
3/27/2020, 11:23:03 AM +59ms
+0ms ╔Received event [Evans St].time = 1585333383665 with a delay of -606ms
+146ms ║RunTime Analysis CS > 30ms > PS > 62ms > PE > 54ms > CE
+149ms ║Runtime (41964 bytes) successfully initialized in 62ms (v0.3.110.20191009) (148ms)
+150ms ║╔Execution stage started
+160ms ║║Cancelling statement #28's schedules...
+186ms ║║Sending internal web request to: 10.1.100.25:8086/query
+190ms ║║Executed virtual command [Plant - Lime Tree].httpRequest (22ms)
+191ms ║║Requesting a wake up for Fri, Mar 27 2020 @ 11:23:23 AM PDT (in 20.0s)
+196ms ║╚Execution stage complete. (45ms)
+197ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:23:23 AM PDT (in 19.995s), with 1 more job pending
+207ms ╚Event processed successfully (207ms)
3/27/2020, 11:22:43 AM +73ms
+1ms ╔Received event [Evans St].wc_async_reply = httpRequest with a delay of 0ms
+112ms ║RunTime Analysis CS > 13ms > PS > 39ms > PE > 60ms > CE
+115ms ║Runtime (41969 bytes) successfully initialized in 39ms (v0.3.110.20191009) (114ms)
+117ms ║╔Execution stage started
+118ms ║╚Execution stage complete. (2ms)
+120ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:23:03 AM PDT (in 20.473s)
+131ms ╚Event processed successfully (130ms)
3/27/2020, 11:22:30 AM +84ms
+0ms ╔Received event [Evans St].time = 1585333351519 with a delay of -1435ms
+158ms ║RunTime Analysis CS > 39ms > PS > 76ms > PE > 42ms > CE
+160ms ║Runtime (41965 bytes) successfully initialized in 76ms (v0.3.110.20191009) (159ms)
+161ms ║╔Execution stage started
+174ms ║║null
+175ms ║║Executed virtual command [Plant - Lime Tree].log (2ms)
+180ms ║║[:]
+181ms ║║Executed virtual command [Plant - Lime Tree].log (1ms)
+184ms ║║Error parsing JSON data [:]
+184ms ║║Executed virtual command [Plant - Lime Tree].parseJson (1ms)
+187ms ║║Error retrieving JSON data part null
+191ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+194ms ║║Error retrieving JSON data part null
+200ms ║║Error retrieving JSON data part null
+205ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+207ms ║║Error retrieving JSON data part null
+211ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+214ms ║║Error retrieving JSON data part null
+218ms ║║Calculating (decimal) 0.0 * (decimal) 1.8 >> (decimal) 0.0
+220ms ║║Calculating (decimal) 0.0 + (decimal) 32.0 >> (decimal) 32.0
+224ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+781ms ║║Executed physical command [Plant - Lime Tree].getBattery([0]) (554ms)
+782ms ║║Executed [Plant - Lime Tree].getBattery (556ms)
+802ms ║║Executed physical command [Plant - Lime Tree].changeMoisture([0]) (16ms)
+802ms ║║Executed [Plant - Lime Tree].changeMoisture (18ms)
+822ms ║║Executed physical command [Plant - Lime Tree].changeFert([0]) (17ms)
+823ms ║║Executed [Plant - Lime Tree].changeFert (19ms)
+842ms ║║Executed physical command [Plant - Lime Tree].changeLight([0]) (16ms)
+843ms ║║Executed [Plant - Lime Tree].changeLight (18ms)
+862ms ║║Executed physical command [Plant - Lime Tree].changeTemp([32.0]) (17ms)
+863ms ║║Executed [Plant - Lime Tree].changeTemp (18ms)
+867ms ║╚Execution stage complete. (706ms)
+868ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:23:03 AM PDT (in 32.713s)
+876ms ╚Event processed successfully (876ms)
3/27/2020, 11:22:21 AM +211ms
+0ms ╔Received event [Evans St].time = 1585333342238 with a delay of -1027ms
+289ms ║RunTime Analysis CS > 72ms > PS > 172ms > PE > 45ms > CE
+292ms ║Runtime (41967 bytes) successfully initialized in 172ms (v0.3.110.20191009) (291ms)
+293ms ║╔Execution stage started
+306ms ║║Executed virtual command [Plant - Lime Tree].wait (0ms)
+307ms ║║Requesting a wake up for Fri, Mar 27 2020 @ 11:22:31 AM PDT (in 10.0s)
+395ms ║╚Execution stage complete. (102ms)
+406ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:22:31 AM PDT (in 9.903s), with 1 more job pending
+415ms ╚Event processed successfully (414ms)
3/27/2020, 11:22:02 AM +75ms
+1ms ╔Received event [Evans St].time = 1585333323665 with a delay of -1590ms
+133ms ║RunTime Analysis CS > 19ms > PS > 51ms > PE > 62ms > CE
+135ms ║Runtime (41965 bytes) successfully initialized in 51ms (v0.3.110.20191009) (134ms)
+146ms ║║Cancelling statement #28's schedules...
+158ms ║║Sending internal web request to: 10.1.100.25:8086/query
+161ms ║║Executed virtual command [Plant - Lime Tree].httpRequest (7ms)
+162ms ║║Requesting a wake up for Fri, Mar 27 2020 @ 11:22:22 AM PDT (in 20.0s)
+167ms ║╚Execution stage complete. (31ms)
+168ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:22:22 AM PDT (in 19.995s), with 1 more job pending
+176ms ╚Event processed successfully (176ms)
3/27/2020, 11:21:32 AM +65ms
+1ms ╔Received event [Evans St].time = 1585333291604 with a delay of 461ms
+151ms ║RunTime Analysis CS > 27ms > PS > 57ms > PE > 67ms > CE
+154ms ║Runtime (41969 bytes) successfully initialized in 57ms (v0.3.110.20191009) (152ms)
+156ms ║╔Execution stage started
+173ms ║║null
+181ms ║║[:]
+182ms ║║Executed virtual command [Plant - Lime Tree].log (2ms)
+187ms ║║Error parsing JSON data [:]
+189ms ║║Executed virtual command [Plant - Lime Tree].parseJson (3ms)
+197ms ║║Executed virtual command [Plant - Lime Tree].setVariable (3ms)
+204ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+212ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+219ms ║║Executed virtual command [Plant - Lime Tree].setVariable (3ms)
+223ms ║║Error retrieving JSON data part null
+229ms ║║Calculating (decimal) 0.0 * (decimal) 1.8 >> (decimal) 0.0
+233ms ║║Calculating (decimal) 0.0 + (decimal) 32.0 >> (decimal) 32.0
+237ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+712ms ║║Executed physical command [Plant - Lime Tree].getBattery([0]) (469ms)
+713ms ║║Executed [Plant - Lime Tree].getBattery (471ms)
+738ms ║║Executed physical command [Plant - Lime Tree].changeMoisture([0]) (21ms)
+739ms ║║Executed [Plant - Lime Tree].changeMoisture (23ms)
+763ms ║║Executed physical command [Plant - Lime Tree].changeFert([0]) (21ms)
+765ms ║║Executed [Plant - Lime Tree].changeFert (23ms)
+789ms ║║Executed physical command [Plant - Lime Tree].changeLight([0]) (21ms)
+790ms ║║Executed [Plant - Lime Tree].changeLight (23ms)
+814ms ║║Executed physical command [Plant - Lime Tree].changeTemp([32.0]) (21ms)
+815ms ║║Executed [Plant - Lime Tree].changeTemp (22ms)
+818ms ║╚Execution stage complete. (663ms)
+819ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:22:03 AM PDT (in 30.781s)
+826ms ╚Event processed successfully (826ms)
3/27/2020, 11:21:29 AM +331ms
+112ms ║RunTime Analysis CS > 15ms > PS > 43ms > PE > 54ms > CE
+114ms ║Runtime (41975 bytes) successfully initialized in 43ms (v0.3.110.20191009) (113ms)
+115ms ║╔Execution stage started
+116ms ║╚Execution stage complete. (1ms)
+117ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:21:31 AM PDT (in 2.156s), with 1 more job pending
+128ms ╚Event processed successfully (127ms)
3/27/2020, 11:21:21 AM +273ms
+1ms ╔Received event [Evans St].time = 1585333282336 with a delay of -1063ms
+313ms ║RunTime Analysis CS > 127ms > PS > 136ms > PE > 49ms > CE
+316ms ║Runtime (41974 bytes) successfully initialized in 136ms (v0.3.110.20191009) (313ms)
+317ms ║╔Execution stage started
+329ms ║║Executed virtual command [Plant - Lime Tree].wait (0ms)
+330ms ║║Requesting a wake up for Fri, Mar 27 2020 @ 11:21:31 AM PDT (in 10.0s)
+335ms ║╚Execution stage complete. (19ms)
+337ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:21:31 AM PDT (in 9.995s), with 1 more job pending
+345ms ╚Event processed successfully (345ms)
3/27/2020, 11:21:02 AM +70ms
+0ms ╔Received event [Evans St].time = 1585333263665 with a delay of -1596ms
+238ms ║RunTime Analysis CS > 87ms > PS > 101ms > PE > 51ms > CE
+241ms ║Runtime (41973 bytes) successfully initialized in 101ms (v0.3.110.20191009) (239ms)
+241ms ║╔Execution stage started
+251ms ║║Cancelling statement #28's schedules...
+262ms ║║Sending internal web request to: 10.1.100.25:8086/query
+264ms ║║Executed virtual command [Plant - Lime Tree].httpRequest (6ms)
+265ms ║║Requesting a wake up for Fri, Mar 27 2020 @ 11:21:22 AM PDT (in 20.0s)
+270ms ║╚Execution stage complete. (29ms)
+272ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:21:22 AM PDT (in 19.995s), with 1 more job pending
+280ms ╚Event processed successfully (280ms)
3/27/2020, 11:20:20 AM +110ms
+1ms ╔Received event [Evans St].time = 1585333221433 with a delay of -1323ms
+396ms ║RunTime Analysis CS > 117ms > PS > 228ms > PE > 51ms > CE
+399ms ║Runtime (41968 bytes) successfully initialized in 228ms (v0.3.110.20191009) (396ms)
+400ms ║╔Execution stage started
+416ms ║║null
+417ms ║║Executed virtual command [Plant - Lime Tree].log (2ms)
+425ms ║║{"results":[{"statement_id":0,"series":[{"name":"monitor_reading","columns":["time","last_battery","last_conductivity","last_light","last_moisture","last_temperature"],"values":[["1970-01-01T00:00:00Z",94,83,4795,43,12.6]]}]}]}
+426ms ║║Executed virtual command [Plant - Lime Tree].log (1ms)
+429ms ║║Executed virtual command [Plant - Lime Tree].parseJson (1ms)
+435ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+441ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+447ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+454ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+460ms ║║Calculating (decimal) 12.6 * (decimal) 1.8 >> (decimal) 22.68
+462ms ║║Calculating (decimal) 22.68 + (decimal) 32.0 >> (decimal) 54.68
+467ms ║║Executed virtual command [Plant - Lime Tree].setVariable (3ms)
+4458ms ║║Executed physical command [Plant - Lime Tree].getBattery([94]) (3988ms)
+4459ms ║║Executed [Plant - Lime Tree].getBattery (3990ms)
+4484ms ║║Executed physical command [Plant - Lime Tree].changeMoisture([43]) (22ms)
+4485ms ║║Executed [Plant - Lime Tree].changeMoisture (24ms)
+4509ms ║║Executed physical command [Plant - Lime Tree].changeFert([83]) (21ms)
+4510ms ║║Executed [Plant - Lime Tree].changeFert (23ms)
+4534ms ║║Executed physical command [Plant - Lime Tree].changeLight([4795]) (20ms)
+4535ms ║║Executed [Plant - Lime Tree].changeLight (23ms)
+4558ms ║║Executed physical command [Plant - Lime Tree].changeTemp([54.0]) (20ms)
+4559ms ║║Executed [Plant - Lime Tree].changeTemp (22ms)
+4562ms ║╚Execution stage complete. (4163ms)
+4564ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:21:03 AM PDT (in 38.992s)
+4572ms ╚Event processed successfully (4571ms)
3/27/2020, 11:20:12 AM +400ms
+106ms ║RunTime Analysis CS > 14ms > PS > 39ms > PE > 53ms > CE
+108ms ║Runtime (41969 bytes) successfully initialized in 39ms (v0.3.110.20191009) (106ms)
+111ms ║╚Execution stage complete. (1ms)
+112ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:20:21 AM PDT (in 8.922s), with 1 more job pending
+124ms ╚Event processed successfully (124ms)
3/27/2020, 11:20:12 AM +211ms
+121ms ║RunTime Analysis CS > 22ms > PS > 45ms > PE > 54ms > CE
+124ms ║Runtime (41969 bytes) successfully initialized in 45ms (v0.3.110.20191009) (123ms)
+126ms ║╚Execution stage complete. (2ms)
+127ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:20:21 AM PDT (in 9.095s), with 1 more job pending
+139ms ╚Event processed successfully (139ms)
3/27/2020, 11:20:11 AM +911ms
+116ms ║RunTime Analysis CS > 19ms > PS > 46ms > PE > 52ms > CE
+119ms ║Runtime (41969 bytes) successfully initialized in 46ms (v0.3.110.20191009) (118ms)
+121ms ║╚Execution stage complete. (2ms)
+122ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:20:21 AM PDT (in 9.4s), with 1 more job pending
3/27/2020, 11:20:11 AM +523ms
+113ms ║RunTime Analysis CS > 16ms > PS > 42ms > PE > 56ms > CE
+115ms ║Runtime (41969 bytes) successfully initialized in 42ms (v0.3.110.20191009) (114ms)
+116ms ║╔Execution stage started
+117ms ║╚Execution stage complete. (1ms)
+119ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:20:21 AM PDT (in 9.792s), with 1 more job pending
+129ms ╚Event processed successfully (129ms)
3/27/2020, 11:20:11 AM +288ms
+129ms ║RunTime Analysis CS > 25ms > PS > 47ms > PE > 57ms > CE
+131ms ║Runtime (41969 bytes) successfully initialized in 47ms (v0.3.110.20191009) (130ms)
+132ms ║╔Execution stage started
+143ms ║║Executed virtual command [Plant - Lime Tree].wait (0ms)
+145ms ║║Requesting a wake up for Fri, Mar 27 2020 @ 11:20:21 AM PDT (in 10.0s)
+149ms ║╚Execution stage complete. (17ms)
+151ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:20:21 AM PDT (in 9.995s), with 1 more job pending
+163ms ╚Event processed successfully (163ms)
3/27/2020, 11:20:03 AM +137ms
+0ms ╔Received event [Evans St].time = 1585333203665 with a delay of -528ms
+642ms ║RunTime Analysis CS > 275ms > PS > 305ms > PE > 61ms > CE
+645ms ║Runtime (41967 bytes) successfully initialized in 305ms (v0.3.110.20191009) (644ms)
+646ms ║╔Execution stage started
+660ms ║║Cancelling statement #28's schedules...
+921ms ║║Sending internal web request to: 10.1.100.25:8086/query
+925ms ║║Executed virtual command [Plant - Lime Tree].httpRequest (252ms)
+927ms ║║Requesting a wake up for Fri, Mar 27 2020 @ 11:20:24 AM PDT (in 20.0s)
+932ms ║╚Execution stage complete. (286ms)
+934ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:20:24 AM PDT (in 19.995s), with 1 more job pending
+941ms ╚Event processed successfully (941ms)
3/27/2020, 11:19:30 AM +76ms
+0ms ╔Received event [Evans St].time = 1585333171196 with a delay of -1121ms
+261ms ║RunTime Analysis CS > 81ms > PS > 139ms > PE > 42ms > CE
+264ms ║Runtime (41973 bytes) successfully initialized in 139ms (v0.3.110.20191009) (263ms)
+265ms ║╔Execution stage started
+278ms ║║null
+279ms ║║Executed virtual command [Plant - Lime Tree].log (1ms)
+284ms ║║[:]
+285ms ║║Executed virtual command [Plant - Lime Tree].log (1ms)
+288ms ║║Error parsing JSON data [:]
+288ms ║║Executed virtual command [Plant - Lime Tree].parseJson (1ms)
+291ms ║║Error retrieving JSON data part null
+296ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+298ms ║║Error retrieving JSON data part null
+302ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+305ms ║║Error retrieving JSON data part null
+309ms ║║Executed virtual command [Plant - Lime Tree].setVariable (3ms)
+312ms ║║Error retrieving JSON data part null
+316ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+319ms ║║Error retrieving JSON data part null
+323ms ║║Calculating (decimal) 0.0 * (decimal) 1.8 >> (decimal) 0.0
+325ms ║║Calculating (decimal) 0.0 + (decimal) 32.0 >> (decimal) 32.0
+329ms ║║Executed virtual command [Plant - Lime Tree].setVariable (2ms)
+2146ms ║║Executed physical command [Plant - Lime Tree].getBattery([0]) (1814ms)
+2147ms ║║Executed [Plant - Lime Tree].getBattery (1816ms)
+2175ms ║║Executed physical command [Plant - Lime Tree].changeMoisture([0]) (23ms)
+2176ms ║║Executed [Plant - Lime Tree].changeMoisture (26ms)
+2204ms ║║Executed physical command [Plant - Lime Tree].changeFert([0]) (23ms)
+2205ms ║║Executed [Plant - Lime Tree].changeFert (26ms)
+2230ms ║║Executed physical command [Plant - Lime Tree].changeLight([0]) (22ms)
+2231ms ║║Executed [Plant - Lime Tree].changeLight (23ms)
+2258ms ║║Executed physical command [Plant - Lime Tree].changeTemp([32.0]) (23ms)
+2259ms ║║Executed [Plant - Lime Tree].changeTemp (25ms)
+2264ms ║╚Execution stage complete. (1999ms)
+2266ms ║Setting up scheduled job for Fri, Mar 27 2020 @ 11:20:03 AM PDT (in 31.324s)
+2274ms ╚Event processed successfully (2273ms)
3/27/2020, 11:19:21 AM +47ms
