@bthrock this has stopped working for me this last week and i’ve no idea why. Is yours still working?
I’m getting the following when I run the token request piston for instance (i’ve changed the token btw)
07/09/2020, 12:11:25 +586ms
+0ms ╔Received event [Home].test = 1599477085585 with a delay of 0ms
+90ms ║RunTime Analysis CS > 20ms > PS > 43ms > PE > 27ms > CE
+92ms ║Runtime (50315 bytes) successfully initialized in 43ms (v0.3.110.20191009) (91ms)
+100ms ║║Cancelling statement #2's schedules...
+131ms ║║Sending external web request to: owner-api.teslamotors.com/oauth/token/
+1046ms ║║Executed virtual command httpRequest (936ms)
+1057ms ║║Calculating (integer) 1 + (integer) 13 >> (integer) 14
+1061ms ║║Executed virtual command setVariable (1ms)
+1073ms ║║Calculating (integer) 84 + (integer) 11 >> (integer) 95
+1086ms ║║Calculating (integer) 107 + (integer) 11 >> (integer) 118
+1091ms ║║Calculating (decimal) 1.599477086E9 + (decimal) 3888000.0 >> (decimal) 1.603365086E9
+1095ms ║║Calculating (decimal) 1.603365086E9 * (decimal) 1000.0 >> (decimal) 1.603365086E12
+1098ms ║║Executed virtual command setVariable (1ms)
+1100ms ║║Cancelling statement #15's schedules...
+1111ms ║║Calculating (string) Bearer + (string) qts-7ba2640dfab4ede614daf71aa38aa6292c15bf4d5c63b6f0ef7f709f9ce9 >> (string) Bearer qts-7ba2640dfab4ede614daf71aa38aa6292c15bf4d5c63b6f0ef7f709f9ce9
+1114ms ║║Sending external web request to: owner-api.teslamotors.com/api/1/vehicles/
+1727ms ║║Error executing external web request: groovyx.net.http.ResponseParseException: Unauthorized
+1728ms ║║Executed virtual command httpRequest (615ms)
+1756ms ║╚Execution stage complete. (1663ms)
+1759ms ║Setting up scheduled job for Tue, Sep 8 2020 @ 12:00:00 AM BST (in 42512.656s)
+1767ms ╚Event processed successfully (1767ms)
