Thermostat and Humidity#2
Tgrant48
My attempt at getting my thermostat to lower (cooling) in 1 degree increments if humidity goes above 60. It does drop it by 1 degree when it goes below 60 but that’s it. Can it be made to continue checking and lowering by 1 if it’s still above 60? Sorry for the blank post. Any help appreciated
Humidity Control Help
c1arkbar
You can use a while loop.
Keep your IF statement. Add a while loop inside that IF statement. While humidity is greater than 60 lower setpoint, wait (insert amount of time before checking again)
End while
End if
Tgrant48
I don’t quite understand how to put in the while loop. Tried reading up on it but…Any help appreciated.
c1arkbar
Ensure that advanced statements are enabled. This setting is under option in the top right of the piston editor. Then select add a new statement. Select while loop.
Trianon
Hi there. Building my first piston.
Could someone post the final code for this.It’s exactly what I am aiming for!
Thanks so much. Hope you all are doing great.
