i am having the same issue with a Ecobee 4.
Issue seems to be at the .355ms
68 is my heating setpoint and 72 is my cooling setpoint (in this mode). It appears that it is just dividing those 2 numbers and getting the .94444444444 as a result.
Logs are as follows:
12/28/2017, 5:47:56 PM +171ms
+0ms ╔Received event [Home].time = 1514504876718 with a delay of -548ms
+201ms ║RunTime Analysis CS > 20ms > PS > 54ms > PE > 128ms > CE
+206ms ║Runtime (79827 bytes) successfully initialized in 54ms (v0.2.101.20171227) (204ms)
+207ms ║╔Execution stage started
+222ms ║║Cancelling statement #160’s schedules…
+227ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+233ms ║║Executed virtual command setVariable (4ms)
+266ms ║║Calculating (string) auto == (string) on >> (boolean) false
+271ms ║║Calculating (string) auto == (string) off >> (boolean) false
+312ms ║║Calculating (string) 20 + (string) °C >> (string) 20°C
+315ms ║║Calculating (string) 68 + (string) °F >> (string) 68°F
+318ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false
+344ms ║║Calculating (string) 22 + (string) °C >> (string) 22°C
+347ms ║║Calculating (string) 72 + (string) °F >> (string) 72°F
+350ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false
+355ms ║║Calculating (decimal) 68.0 / (decimal) 72.0 >> (decimal) 0.9444444444444444
+358ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+362ms ║║Calculating (string) auto == (string) off >> (boolean) false
+405ms ║║Calculating (string) 22 + (string) °C >> (string) 22°C
+409ms ║║Calculating (string) 72 + (string) °F >> (string) 72°F
+412ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false
+417ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+421ms ║║Calculating (string) auto == (string) off >> (boolean) false
+461ms ║║Calculating (string) 20 + (string) °C >> (string) 20°C
+464ms ║║Calculating (string) 68 + (string) °F >> (string) 68°F
+467ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false
+472ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+476ms ║║Calculating (string) auto == (string) off >> (boolean) false
+481ms ║║Calculating (string) auto == (string) heat >> (boolean) false
+486ms ║║Calculating (string) auto == (string) cool >> (boolean) false
+490ms ║║Calculating (string) auto == (string) auto >> (boolean) true
+494ms ║║Calculating (string) heating == (string) idle >> (boolean) false
+553ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+557ms ║║Calculating (string) auto == (string) heat >> (boolean) false
+561ms ║║Calculating (string) auto == (string) cool >> (boolean) false
+565ms ║║Calculating (string) auto == (string) auto >> (boolean) true
+569ms ║║Calculating (string) auto == (string) off >> (boolean) false
+591ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+595ms ║║Calculating (string) auto == (string) off >> (boolean) false
+619ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+623ms ║║Calculating (string) auto == (string) off >> (boolean) false
+646ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+650ms ║║Calculating (string) auto == (string) off >> (boolean) false
+655ms ║║Calculating (string) auto == (string) heat >> (boolean) false
+659ms ║║Calculating (string) auto == (string) cool >> (boolean) false
+663ms ║║Calculating (string) auto == (string) auto >> (boolean) true
+668ms ║║Calculating (string) heating == (string) idle >> (boolean) false
+674ms ║║Calculating (string) 25 + (string) % >> (string) 25%
+677ms ║║Calculating (string) 25% + (string) >> (string) 25%
+728ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+732ms ║║Calculating (string) auto == (string) heat >> (boolean) false
+737ms ║║Calculating (string) auto == (string) cool >> (boolean) false
+741ms ║║Calculating (string) auto == (string) auto >> (boolean) true
+745ms ║║Calculating (string) auto == (string) off >> (boolean) false
+767ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+771ms ║║Calculating (string) auto == (string) off >> (boolean) false
+794ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+799ms ║║Calculating (string) auto == (string) off >> (boolean) false
+820ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+824ms ║║Calculating (string) auto == (string) off >> (boolean) false
+829ms ║║Calculating (string) auto == (string) heat >> (boolean) false
+833ms ║║Calculating (string) auto == (string) cool >> (boolean) false
+837ms ║║Calculating (string) auto == (string) auto >> (boolean) true
+841ms ║║Calculating (string) heating == (string) idle >> (boolean) false
+847ms ║║Calculating (string) 25 + (string) % >> (string) 25%
+849ms ║║Calculating (string) 25% + (string) >> (string) 25%
+854ms ║║Calculating (string) 19 + (string) °C >> (string) 19°C
+870ms ║║Calculating (string) 19°C + (string) 25% >> (string) 19°C 25%
+873ms ║║Calculating (string) 67 + (string) °F >> (string) 67°F
+878ms ║║Calculating (string) 67°F + (string) 25% >> (string) 67°F 25%
+881ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false
+908ms ║║Calculating (string) auto == (string) on >> (boolean) false
+912ms ║║Calculating (string) auto == (string) off >> (boolean) false
+935ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+939ms ║║Calculating (string) auto == (string) off >> (boolean) false
+962ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+966ms ║║Calculating (string) auto == (string) off >> (boolean) false
+988ms ║║Calculating (string) heating == (string) fan only >> (boolean) false
+993ms ║║Calculating (string) auto == (string) off >> (boolean) false
+998ms ║║Calculating (string) auto == (string) heat >> (boolean) false
+1002ms ║║Calculating (string) auto == (string) cool >> (boolean) false
+1006ms ║║Calculating (string) auto == (string) auto >> (boolean) true
+1011ms ║║Calculating (string) heating == (string) idle >> (boolean) false
+1016ms ║║Executed virtual command setTile (2ms)
+1020ms ║║Cancelling statement #169’s schedules…
+1025ms ║║Executed virtual command setVariable (3ms)
+1033ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1039ms ║║Cancelling statement #172’s schedules…
+1042ms ║║Executed virtual command clearTile (1ms)
+1050ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1054ms ║║Cancelling statement #172’s schedules…
+1057ms ║║Executed virtual command clearTile (0ms)
+1065ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1071ms ║║Cancelling statement #172’s schedules…
+1077ms ║║Executed virtual command clearTile (2ms)
+1085ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1090ms ║║Cancelling statement #172’s schedules…
+1093ms ║║Executed virtual command clearTile (0ms)
+1100ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1105ms ║║Cancelling statement #172’s schedules…
+1109ms ║║Executed virtual command clearTile (0ms)
+1116ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1121ms ║║Cancelling statement #172’s schedules…
+1125ms ║║Executed virtual command clearTile (0ms)
+1132ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1137ms ║║Cancelling statement #172’s schedules…
+1140ms ║║Executed virtual command clearTile (0ms)
+1148ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1153ms ║║Cancelling statement #172’s schedules…
+1157ms ║║Executed virtual command clearTile (1ms)
+1165ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1170ms ║║Cancelling statement #172’s schedules…
+1173ms ║║Executed virtual command clearTile (1ms)
+1181ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1185ms ║║Cancelling statement #172’s schedules…
+1189ms ║║Executed virtual command clearTile (0ms)
+1196ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1201ms ║║Cancelling statement #172’s schedules…
+1204ms ║║Executed virtual command clearTile (0ms)
+1212ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1216ms ║║Cancelling statement #172’s schedules…
+1219ms ║║Executed virtual command clearTile (0ms)
+1227ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1231ms ║║Cancelling statement #172’s schedules…
+1234ms ║║Executed virtual command clearTile (0ms)
+1242ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1246ms ║║Cancelling statement #172’s schedules…
+1250ms ║║Executed virtual command clearTile (0ms)
+1257ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1261ms ║║Cancelling statement #172’s schedules…
+1264ms ║║Executed virtual command clearTile (0ms)
+1268ms ║╚Execution stage complete. (1062ms)
+1270ms ║Setting up scheduled job for Thu, Dec 28 2017 @ 5:48:36 PM CST (in 39.278s)
+1281ms ╚Event processed successfully (1282ms)
