I have recently received my Samsung Hub 3 and two sensors, a EcoLink tilt sensor for my garage door and Samsung Leak Sensor.
I have set a couple simple piston and Im having random times when the piston is executing twice and sending multiple notifications.
This is issue is happening with both sensors. As you can see below I have tried using a variable to stop the second notification but this did not work. I also saw another post that indicated enabling parallelism helped but neither of these work for me.
My feeling is that its one of two things
- I originally had the new Smartthings app installed until I realized that Webcore only works with classic app. So I installed classic but realized that with both apps installed I was getting double alerts from a piston. I then uninstalled the newer app and no longer receive alerts from it. Is it possible that somehow Im receiving two alert from the classic app because its still thinks the newer app is running?
- Hub 3 is new and there is a bug with webcore?
