Txt message trigger
Is there a way to build in a native trigger for a SMS message? @ady624
Basically txt a number with preset words as triggers.
So basically send txt. Txt sets a global variable.
I.e.
If variable changes, then if variable = xyz then do …
I wonder if it could be setup for WC to monitor a google voice account. Link GV account in WC settings. And then user just txts a GV#.
So each user just uses/gives out their GV# to family to use.
Have it where it’s linked to a universal piston where if a user doesn’t know all the commands, they can text the word commands, or list to that number and it will return a list of all the variable presets
I think you can already do this via IFTTT but it would certainly be a neat built in feature!!
Twilio integration has been on the todo list from early on… that would open a lot of possibilities if/when it comes to fruition.
