Hi - I recently discovered I’m not able to install the WebCore smartapp when I select it from the Marketplace. When I select it, it goes to another page with a spinning circle and then says “Oops something when wrong”. I did recently update to v0.3.10a20190223 so not sure if that is the cause. I do have a previously installed instance of the WebCore smartapp that seems to be working so this only seems to be affecting new installs. Has anyone else seen this before? The below is what I get from live logging.
Not parsing XML message:
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body>
<u:GetVolumeResponse xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1">
<CurrentVolume>
19
</CurrentVolume>
</u:GetVolumeResponse>
</s:Body>
</s:Envelope>
