I updated to a Samsung account and now WC does not work. I googled around a bit but cannot find anything related, I assume it’s some simple “just change this” and it will work.
Any ideas?
Any ideas?
Any info on what doesn’t work?
Do you see the apps still installed?
Are you seeing any logs in the IDE? Is the app (webCoRE) still on your phone?
If I change modes (home, away, etc) I see it change in webcore.
You know the device list you see on the right side when you are editing a piston? Its accurate. If I change a device in the ST app and refresh the WC page they change.
I still have the webcore app on my phone.
What doesn’t work.
None of my pistons are working. Example - I have a simple piston that turns off some lights. Its executed using a virtual switch. I have logging set to full on this piston. When I execute the piston… nothing happens a nothing changes in the piston log.
If this piston… I turned the VS on an off 5 times… nada in the logs and the Close All piston was not executed.
Same when I run " External URL: [(click to open/execute)]"
