Well, it works in a block by itself, or else your 5am and sunset blocks would not be working. I will shoot you a message when I have enough data gathered to make a proper post for reference.
Using multiple TRIGGERS in single IF
ike2018
#22
those also did not work:)))
at 5am it did not change…
I am not sure about the sunset but I will test it tonight.
WCmore
#23
Ahh, then perhaps using the Timer is the solution for those blocks as well…
I cannot remember the last time I put a time statement as a trigger in an IF block.
I usually do this instead:
(although I may place conditions in the next line or two)
Happens Daily, doesn't
ike2018
#24
Changed everything to timers as you suggested…
So far, 1hours to sunset worked perfectly…
UPDATE;
7.00 am also worked:)))
