Here’s my Water Leak Sensor that will send you an alert via SMS and PUSH Notification. Code: 5egp7
You will have to customize for your needs:
Modify the Water Sensor Device to the one you want to setup. This piston is designed for 1 water sensor, just import this one multiple times if you have more than 1.
It shows Kitchen Sink on the alerts for the Push and SMS Notifications, change to the name of your device on the 5 variables for the notifications on the top.
Change the SMSAlert1 to your Cell Number. My suggestion though is setup a Global variable for each Cell Number and use that instead but I added for the purpose of posting here if you don’t use a Global Variable. Here’s what my Global Variable looks like:
I setup where my light flashes with color, you may need to modify based on the lights you want to flash and if you have color bulbs.
