webCoRE Presence with multiple instances
Understanding that there is a limitation on having 10 locations per instance using the webCoRE Presence sensor. I tried setting up a second instance connected to the same hub so I could add an additional 10 locations. Problem is when I look a the webCoRE Presence sensor in my list of devices it only displays the first 10 locations from my main instance. How do I get the other instances locations to show up so they can be used? Do I need to do something to authorize those devices? I tried going into the second instance and making the presence sensor available as a device but that did not seem to help. Any suggestions would be appreciated.
split this topic #2
2 posts were merged into an existing topic: Getting around 10 location limit in webcore more presence places
closed #3
