I use Smartthings location mode as an input for one of my pistons. When the location mode changes to “stay”, I want another action to run to keep my keypad in sync. The piston I’ve been using for quite a while for this suddenly stopped working over the last couple of days.
Location mode changes to “stay” and keypad is set to its “stay” mode.
In tracing the piston, it appears as if Webcore never sees that the location mode changes. All built-in Smartthings Automations using location modes are working fine.
8/26/2021, 6:20:17 AM +144ms
+0ms ╔Starting piston… (v0.3.113.20210203)
+400ms ║╔Subscribing to devices…
+406ms ║║Subscribing to Home.mode…
+455ms ║║Subscribing to Keypad…
+456ms ║╚Finished subscribing (67ms)
+483ms ║Comparison (string) :afd954100a49a551fe6758c3b9c6098e: changes_to (string) :f4d313ed72df2304f8e113294f8ec02c: = false (1ms)
+491ms ╚Piston successfully started (491ms)
8/26/2021, 6:13:05 AM +561ms
+1ms ╔Starting piston… (v0.3.113.20210203)
+380ms ║╔Subscribing to devices…
+408ms ║║Subscribing to Home.mode…
+469ms ║║Subscribing to Keypad…
+469ms ║╚Finished subscribing (99ms)
+493ms ║Comparison (string) :afd954100a49a551fe6758c3b9c6098e: changes_to (string) :f4d313ed72df2304f8e113294f8ec02c: = false (1ms)
+504ms ╚Piston successfully started (504ms)
8/25/2021, 10:27:50 PM +416ms
+371ms ║╔Subscribing to devices…
+401ms ║║Subscribing to Home.mode…
+468ms ║║Subscribing to Keypad…
+469ms ║╚Finished subscribing (110ms)
+496ms ║Comparison (string) :f4d313ed72df2304f8e113294f8ec02c: changes_to (string) :f4d313ed72df2304f8e113294f8ec02c: = false (0ms)
+497ms ║Cancelling condition #2’s schedules…
+499ms ║Cancelling condition #1’s schedules…
+513ms ╚Piston successfully started (513ms)
8/25/2021, 10:25:33 PM +734ms
+364ms ║╔Subscribing to devices…
+428ms ║║Subscribing to Home.mode…
+515ms ║║Subscribing to Keypad…
+517ms ║╚Finished subscribing (162ms)
+541ms ║Comparison (string) :f4d313ed72df2304f8e113294f8ec02c: changes_to (string) :f4d313ed72df2304f8e113294f8ec02c: = true (1ms)
+543ms ║Cancelling condition #2’s schedules…
+544ms ║Cancelling condition #1’s schedules…
+561ms ╚Piston successfully started (559ms)
8/25/2021, 10:24:30 PM +875ms
+1ms ╔Received event [Home].test = 1629944670875 with a delay of 0ms
+56ms ║RunTime Analysis CS > 15ms > PS > 6ms > PE > 35ms > CE
+60ms ║Runtime (36732 bytes) successfully initialized in 6ms (v0.3.113.20210203) (57ms)
+62ms ║╔Execution stage started
+69ms ║║Comparison (string) :afd954100a49a551fe6758c3b9c6098e: changes_to (string) :f4d313ed72df2304f8e113294f8ec02c: = false (1ms)
+72ms ║║Condition #2 evaluated false (6ms)
+73ms ║║Condition group #1 evaluated false (state did not change) (7ms)
+77ms ║╚Execution stage complete. (16ms)
+79ms ╚Event processed successfully (78ms)
8/25/2021, 10:20:20 PM +716ms
+2ms ╔Starting piston… (v0.3.113.20210203)
+398ms ║╔Subscribing to devices…
+463ms ║║Subscribing to Home.mode…
+583ms ║║Subscribing to Keypad…
+585ms ║╚Finished subscribing (192ms)
+612ms ║Comparison (string) :afd954100a49a551fe6758c3b9c6098e: changes_to (string) :f4d313ed72df2304f8e113294f8ec02c: = false (1ms)
+634ms ╚Piston successfully started (633ms)
8/25/2021, 10:20:18 PM +620ms
+62ms ╔Stopping piston…
+148ms ╚Piston successfully stopped (87ms)
