I keep noticing a [User Verification Not Started] red block appearing when I post. What’s the process for verification and how do I get it started?
Thanks.
What is the process for User Verification?
qoheleth
Robin
All new users get the ‘verification not started’ flag by default.
I run a verification cycle every couple of weeks:
- Users with names that match a user on the ST forum are flagged as ‘ST user pending verification’ and I send them a PM on the ST forum requesting that they verify they are the same person.
- Users with different names do not need verification, therefore all flags are removed.
There is nobody using @qoheleth on ST as you are using @qoheleth.rms over there, so I’ll remove your flag right away… this would have happened automatically on the next cycle but no point waiting in your case.
Robin
I have a problem with the script I run on the ST forum, which I use to compare names… so I currently rely on ST forum users sending me a PM on the ST forum, as per the instructions as sign-up.
I see you have just send me said PM, and I will now verify your profile.
