What would this return
hi
@@SumpPump1TriggerTime = $now
($now-@@SumpPump1TriggerTime)/60000
what value would ts return is it
hmm run time in minutes?
when coding is there a way to go through the code an see what it gives you
Assuming the values for the other variables are present, you can try the Evaluation console (in non-edit mode, scroll all the way down the piston).
Instead of Value, select Expression. The you can enter ($now-@@SumpPump1TriggerTime)/60000
Edit: The evaluation console is also available in edit mode by the way, it is also possible to preview the evaluation in Expression editor.
I see the evaluation console in edit it a gray box how do i get it to work?
thank that is a big help
