I believe lat/long is provided so you could use this if you want to get the local time at the location of launch:
EDIT: Nevermind, you have to pay a minimum $5/month for this service.
T-99 minutes to launchā¦
(the window is precise here, with only one shot to launch)
There is a live feed here.
Currently, the launch is a āNo-Goā, but they expect the weather to clearā¦
Cape Canaveral weather conditions on WUnderground.
I think with the latest tech, the launch is 99% hands-free for the astronauts insideā¦
(mostly just āside-swipingā to see a different display)
I made that same comment. For the most part they just sat there and watched the screens. Very cool none the less.
So as a follow up the entire piston worked great except for the spoken section gave me a verbal error through Alexa but I think thats an issue beyond WebCore. Very happy with how it all worked out
I donāt use Echo Speaks, so that bit was just added for you guys to play around with.
(any normal voice command using that Expression should work as expected)
So where do we stand on this? @WCmore are you going to take a stab at a two piston approach? I donāt want to put too much work into this if you (Or someone else) are already working on it. If there is anything you would like me to help with Iāll be happy to pitch in.
For a piston to make good use of an API, the coder (me) should have a good understanding of how the API functions⦠How often it updates⦠Under what circumstances are nulls returned etc.
So my current piston works well (with one minor update coming tomorrow)⦠but with the size restraints, I cannot add much more without running out of room. So a two piston sounds like the way to go. (Iāve left out too many features already).
This also means that I may (should) monitor the API for a bit⦠So my coding afterwards is professionalā¦
If you want to customize it yourself, please feel free.
(Any time spent learning or having fun is time well spent)
Me personally?
I need to become better aware of a few other dataPoints that sometimes returns unexpected results.
(For example: Chinaās launch in an hour does not have any weather data in their API:)
⦠so my current piston shows:
Which, although technically accurate, I donāt like itā¦
I can code it to look much better in the hover text.
(if I had enough space to code, that is)
Itās worth noting that⦠a second China launch was also inserted at nearly the last minute⦠
I can see this perspective⦠but also⦠with China slipping in at the last moment, and intentionally posting no relevant data⦠I am wondering if it is worth it⦠Maybe I should code it to update every 6 hours⦠With a bonus update after a launch⦠Hmmmā¦
For those curious, I do have an ulterior motive: I am really trying to respect the owners of the API⦠The more frequent our requests, the higher their monthly bill.
Surely 4-5 times a day is sufficient?
Edit:
Bonus points because āEvery 6 hoursā means every import of the piston will fire at a different time!
Mine is still showing some Florida Starlink data. Need to take a look to see if I screwed up a refresh interval somewhere.
5/31/2020, 8:56:50 AM +206ms
+10163ms āPiston waited at a semaphore for 10029ms
5/31/2020, 7:57:20 AM +77ms
+1739ms āThe next launch is scheduled for Sun, May 31 2020 @ 3:57:21 AM EDT (-4 hrs)
+1739ms āStarlink-8
+1739ms āSpaceX plans to launch Falcon 9, from Cape Canaveral AFS, Florida, on pad SLC-40.
+1739ms āA SpaceX Falcon 9 rocket will launch the Starlink-8 mission. The launch date is currently targeted for June 03, 2020 (UTC).
+1739ms ānullVariable āTags:_tagsā not found
5/31/2020, 7:37:32 AM +718ms
+1629ms āThe next launch is scheduled for Sun, May 31 2020 @ 3:37:34 AM EDT (-4 hrs)
+1629ms āStarlink-8
+1629ms āSpaceX plans to launch Falcon 9, from Cape Canaveral AFS, Florida, on pad SLC-40.
+1630ms āA SpaceX Falcon 9 rocket will launch the Starlink-8 mission. The launch date is currently targeted for June 03, 2020 (UTC).
+1630ms ānullVariable āTags:_tagsā not found
5/31/2020, 7:16:56 AM +810ms
+2118ms āThe next launch is scheduled for Sun, May 31 2020 @ 3:16:58 AM EDT (-4 hrs)
+2118ms āStarlink-8
+2118ms āSpaceX plans to launch Falcon 9, from Cape Canaveral AFS, Florida, on pad SLC-40.
+2118ms āA SpaceX Falcon 9 rocket will launch the Starlink-8 mission. The launch date is currently targeted for June 03, 2020 (UTC).
+2118ms ānullVariable āTags:_tagsā not found
5/30/2020, 5:56:16 PM +139ms
+531ms āThe next launch is scheduled for Thu, Jun 11 2020 @ 12:43:00 AM EDT (11.3 days)
+531ms ā"Donāt Stop Me Now" (ELaNa 32)
+531ms āRocket Lab plans to launch Electron, from Rocket Lab Launch Complex, Mahia Peninsula, New Zealand, on pad LC-1.
+531ms āA Rocket Lab Electron rocket will launch the āDonāt Stop Me Nowā (ELaNa 32) mission on Thursday, June 11, 2020 at 4:43 AM (UTC).
+531ms ānullVariable āTags:_tagsā not found
5/30/2020, 5:36:17 PM +172ms
+2337ms āThe next launch is scheduled for Thu, Jun 11 2020 @ 12:43:00 AM EDT (11.3 days)
+2337ms ā"Donāt Stop Me Now" (ELaNa 32)
+2337ms āRocket Lab plans to launch Electron, from Rocket Lab Launch Complex, Mahia Peninsula, New Zealand, on pad LC-1.
+2337ms āA Rocket Lab Electron rocket will launch the āDonāt Stop Me Nowā (ELaNa 32) mission on Thursday, June 11, 2020 at 4:43 AM (UTC).
+2337ms ānullVariable āTags:_tagsā not found
5/30/2020, 5:16:16 PM +142ms
+2309ms āThe next launch is scheduled for Sat, May 30 2020 @ 3:22:00 PM EDT (-2 hrs)
+2310ms āCrew Dragon Demo-2 (DM-2)
+2310ms āSpaceX plans to launch Falcon 9, from Kennedy Space Center, Florida, on pad LC-39A.
+2310ms āA SpaceX Falcon 9 rocket launched the Crew Dragon Demo-2 (DM-2) mission on Saturday, May 30, 2020 at 7:22 PM (UTC).
+2310ms āFor the first time since the last flight of the Space Shuttle in 2011, U.S. astronauts will go to orbit from American soil. As part of NASAās Commercial Crew Program, SpaceXās Falcon 9 will launch the Crew Dragon spacecraft to the International Space Station.Variable āTags:_tagsā not found
The ānext launch is scheduled forā section came out wrong because the API only listed the day as 3 instead of 03⦠So I need to tweak my code a bit to account for that.
Also, I just noticed a missing quote for tags, so that was my bad.
Expect an update in about 20 minutesā¦
My piston in the original post has been updated with a handful of small tweaks.
(the changes are mostly date and time related)
I also limited the location in the tile to the first 20 characters, so it will always be legibleā¦
(the hover text will still show the full location name)
@guxdude, itās worth mentioning that I had to tweak your {tzOffset} to make it work consistently.
Note for updaters⦠Please donāt forget to change the first line after āexecuteā to a different minute than 6 so we spread out our queries⦠(and of course, delete or pause your old piston)
New screenshot:
