This piston is to turn on a single IKEA Tradfri GU10 I have in my hallway after sunset, if I’m home. Then, once another piston changes my location mode to Night, this piston is meant to trigger and turn off that light. The part of the piston which turns on this light fires without fail every day, no issues. However, the second part of the piston which is meant to turn off the light initially fired sometimes and now isn’t firing at all. I know the location mode is changing to ‘Night’ everyday successfully because I have a push notification configured to confirm it. So I don’t understand why this piston isn’t picking up that change and turning off the light.
Second part of piston should trigger when my location mode changes to ‘Night’ resulting in the light being switched off.
Despite the location mode successfully changing to ‘Night’, the hallway light isn’t being turned off. I checked the logs of this piston and the only time it registers events is at sunset when the light turns on. It doesn’t seem to be registering the location mode change to ‘Night’ at all.
I’m pasting two days worth of logs…
12/9/2020, 4:13:59 PM +72ms
+1ms ╔Received event [Home].time = 1607530440000 with a delay of -928ms
+128ms ║RunTime Analysis CS > 23ms > PS > 53ms > PE > 52ms > CE
+131ms ║Runtime (40155 bytes) successfully initialized in 53ms (v0.3.110.20191009) (129ms)
+132ms ║╔Execution stage started
+164ms ║║Comparison (time) 58439209 happens_daily_at (time) 1607529180000 = true (0ms)
+165ms ║║Time restriction check passed
+167ms ║║Condition #6 evaluated true (29ms)
+168ms ║║Cancelling statement #6's schedules...
+172ms ║║Requesting time schedule wake up at Thu, Dec 10 2020 @ 4:13:00 PM GMT
+182ms ║║Comparison (long) 60929019 is_greater_than (integer) 600000 = true (2ms)
+183ms ║║Condition #22 evaluated true (9ms)
+187ms ║║Comparison (string) :d3dc195c6ea99304d142f80151ca8da2: is (string) :d3dc195c6ea99304d142f80151ca8da2: = true (1ms)
+189ms ║║Condition #26 evaluated true (4ms)
+190ms ║║Condition group #1 evaluated true (state did not change) (53ms)
+192ms ║║Cancelling statement #9's schedules...
+205ms ║║Executed physical command [Hallway Spotlight].on() (10ms)
+206ms ║║Executed [Hallway Spotlight].on (12ms)
+220ms ║║Executed physical command [Hallway Spotlight].setLevel([20]) (11ms)
+221ms ║║Executed [Hallway Spotlight].setLevel (11ms)
+232ms ║║Executed virtual command [Hallway Spotlight].sendPushNotification (8ms)
+238ms ║║Comparison (string) :d3dc195c6ea99304d142f80151ca8da2: changes_to (string) :c465aace1b0b65e0843af2bee0c2ad3e: = false (0ms)
+239ms ║║Condition #21 evaluated false (4ms)
+240ms ║║Condition group #17 evaluated false (state did not change) (5ms)
+242ms ║╚Execution stage complete. (111ms)
+243ms ║Setting up scheduled job for Thu, Dec 10 2020 @ 4:13:00 PM GMT (in 86340.685s)
+251ms ╚Event processed successfully (251ms)
12/8/2020, 4:13:59 PM +93ms
+0ms ╔Received event [Home].time = 1607444040000 with a delay of -908ms
+131ms ║RunTime Analysis CS > 23ms > PS > 53ms > PE > 56ms > CE
+134ms ║Runtime (40155 bytes) successfully initialized in 53ms (v0.3.110.20191009) (133ms)
+135ms ║╔Execution stage started
+171ms ║║Comparison (time) 58439233 happens_daily_at (time) 1607442840000 = true (0ms)
+173ms ║║Time restriction check passed
+174ms ║║Condition #6 evaluated true (34ms)
+175ms ║║Cancelling statement #6's schedules...
+180ms ║║Requesting time schedule wake up at Wed, Dec 9 2020 @ 4:14:00 PM GMT
+189ms ║║Comparison (long) 60940820 is_greater_than (integer) 600000 = true (1ms)
+191ms ║║Condition #22 evaluated true (8ms)
+194ms ║║Comparison (string) :d3dc195c6ea99304d142f80151ca8da2: is (string) :d3dc195c6ea99304d142f80151ca8da2: = true (1ms)
+196ms ║║Condition #26 evaluated true (4ms)
+197ms ║║Condition group #1 evaluated true (state did not change) (58ms)
+199ms ║║Cancelling statement #9's schedules...
+213ms ║║Executed physical command [Hallway Spotlight].on() (11ms)
+214ms ║║Executed [Hallway Spotlight].on (13ms)
+228ms ║║Executed physical command [Hallway Spotlight].setLevel([20]) (11ms)
+229ms ║║Executed [Hallway Spotlight].setLevel (13ms)
+243ms ║║Executed virtual command [Hallway Spotlight].sendPushNotification (10ms)
+248ms ║║Comparison (string) :d3dc195c6ea99304d142f80151ca8da2: changes_to (string) :c465aace1b0b65e0843af2bee0c2ad3e: = false (0ms)
+250ms ║║Condition #21 evaluated false (3ms)
+251ms ║║Condition group #17 evaluated false (state did not change) (5ms)
+253ms ║╚Execution stage complete. (118ms)
+254ms ║Setting up scheduled job for Wed, Dec 9 2020 @ 4:14:00 PM GMT (in 86400.653s)
+262ms ╚Event processed successfully (262ms)
