Adjust Level always turns lights on to 100
I have a very simple piston to turn on lights to 50% when a motion activates. The light turns on but it turns on to 100% every time. I have this implemented in multiple pistons but none of the Adjust Level settings works and lights turn on to 100% each time. Is this a known issue? I seem to have taken a step back by moving to WebCore if this doesn’t work.
Thanks!
Can you show logs for the piston execution? and show the piston?
Are you sure you are up to date on webCoRE install on HE - if user install do HPM repair, or ensure you are up to date on HE firmware if doing built-in
Hi @E_Sch: I figured out my dumb mistake. Thanks for asking. I was using Adjust Level and not Set Level. It all works great now.
