Cost me a little time to figure out what was going on.
18 * -2 = -2
18 * (-2) = -36
18 * 2 = 36
I can work around this obviously, but is that a bug?
18 * -2 = -2
18 * (-2) = -36
18 * 2 = 36
Sounds like a bug. My guess is it’s putting a zero between the * and -, so “18 * 0 - 2 = -2”. But that’s just a guess.
@ipaterson looks like evaluate expression is not handling the special case of operand followed by a negative number and treats the - as an operand instead.
To at least explain the result, this is getting evaluated as
| +240ms | ║2.0 * 0.0 |
| +247ms | ║0.0 - 1.0 |
I can’t promise anything here since the code that evaluates expressions is very complex but if it turns out to be an obvious fix I’ll give you folks something to test
The expression 2 * -1 resulted in these three expression components:
| +200ms | ║║item [t:integer, v:2, d:0, o:*] |
| +200ms | ║║item [t:null, v:0, o:-] |
| +201ms | ║║item [t:integer, v:1, d:0, o:+] |
As far as I could tell, this unary negation was always represented by t:null regardless of whether it was followed by a number, a variable, or other. The correct fix seems to be changing line 5384 of the webCoRE Piston Smart App from
if (((item.o) == '!') || ((item.o) == '!!') || ((item.o) == '~')) break;
to
if (((item.o) == '!') || ((item.o) == '!!') || ((item.o) == '~') || (item.t == null && item.o == '-')) break;
I am out of time today, would anyone like to try out this tweak with a variety of expressions?
This should be fixed in today’s v0.3.104.20180323 release which will require updating your smartapps at ide.smartthings.com and possibly hard refreshing the dashboard.
