Button (mi cube) does not re-register
Howdy webCoRE community!
My setup uses two Xiaomi Mi Cubes as controllers for a bedroom light. The cubes perform the same actions.
Recently one of my cubes stopped working, so I deleted it from the Smartthings app and added it back with the same name (Cube 2). It is now visible in the Smartthings app, and the log (Recents) shows that it is sending events correctly.
Unfortunately it is no longer visible in webCoRE. Cube 1 is visible and it’s working properly, but Cube 2 is just not there any more.
Any suggestions?
Thanks!
In the ST app, go to Automation: Smartapps and select your WC instance, choose settings: available devices and contacts: available devices. Go through the list and add your cube2.
Wonderful, thank you. It’s working now. I had forgotten about that step.
