Spinning boxes of death. Any one else?
Can't Load the Dashboard - Sept 14, 1:50 PM CDT
Have you tried cleaning up and rebuilding the data cache in the webcore smartapp settings?
Will try now.
EDIT:
Thanks, that did it.
Pistons had been loading and saving slowly lately. I guess related? Seems better now.
Actually, it looks like I have a bad piston. I was editing a paused piston that has run before just fine. I made some minor changes and tried to save and that’s when this happened. Doing as you suggested clears the problem until I try editing that same piston again and it hangs on the save and I can’t get the dashboard to load again … It looks like the piston gets to 22 of 23 chunks then fails.
Yeah, hard limit is 25 AFAIK and sometime it fails when getting very close to 25. Then, you get the SSoD (spinning squares of death) and need to clean and rebuild.
Right but it seems this piston is FUBARd now as I can clean and rebuild but each time I update the piston and save it dies again. The piston is not that large and in use by others. I can’t even EDIT then save without making any changes.
I think from my bad memory, I had this happen once. So I tried creating a duplicate piston of it and then had no problems saving it after.
Worth a try?
I gave this a try folks and no cigar. Same problem with the new piston created from the troublesome one.
The SmartApp shows 95% mem usage before I run the clean-up.
Damn, that looks like a sexy piston. I’d be curious to see it if you can take screenshot.
Was there a solution to this? I get the spinning boxes of death on Chrome/IE/Android. I have cleared the cache.
This used to work when I was testing a while ago but now that I want to start converting my pistons it knows I want in
I do see a flash of a few HTML lines on the screen before the screen clears and then the boxes spin.
Running the latest code.
