I posted this on the old forum, but thought I’d repost it here. This uses an RGB bulb to change color based on the temperature outside. It uses SmartWeather device as the temperature sensor. Colors advance through the spectrum from 0F-100F, getting bluer for cold, redder for hot, and all in between. If it’s below 0 or above 100, the bulb flashes three times.
***** Edit:** There is a better updated version here that uses the rainbow value to make a gradient: Change RGB bulb color based on local outside temperature
