you mean clicking “Refresh client secret (warning: this will make your current secret invalid)”
I have tried that also
Ok, dive in with me here. I get the impression that you’re at least fairly technical, so let me know if you need more info on any of the steps I gloss over below.
First thing to figure out is whether a specific piston is responsible for this. You’re already at step 4 since you showed the URL but other steps included for the benefit of others.
dashboard/load
/intf/dashboard/load? with /intf/dashboard/piston/get?id=& but don’t load that page yet because we need to get the id:19ac3370d57aafca115c3f7033ed973c:, including the colonsid= and the & in the earlier URLangular.callbacks
If it looks like all of them will error out after trying a few that’s fine we can look for something else. Otherwise, my hope is that one but not all of these will throw an error.
Seems like I did something wrong - will check again but I get:
angular.callbacks._2({“name”:“NC \ webCoRE_1”,“error”:“ERR_INVALID_TOKEN”,“now”:1510258545656})
I also remember with old CoRE, when I reset the token I had to do something in the mobile app after… will dig into some of my old posts.
The /load shows the same error though when a token is invalid so I think it might be how you edited it. Can you paste here redacted or in a PM to me?
I keep thinking something is broken somewhere like that - some thing that hooks all this magic together I just have no idea where to find it.
The URL included /intf/dashboard/load?token=&pin= with a value for the pin but no token. I think something got stuck halfway through signing you in to the dashboard. Open up the browser console and run the command localforage.clear();
This will reset the data cached in your browser and require you to re-authorize that browser to use webCoRE. Once you’ve done that let’s see if it loads up or if we need to keep debugging.
So I register and then next screen asks me my password. When I enter that I get stuck and I get the 500 error. Token is blank
I take it you’ve tried the dashboard button in the mobile app instead of register a browser?
Have you tried going to the smartapps tab of a device and accessing a piston from there?
Are you able to install a second instance and access that?
Ok, so I see that the token comes back from a call to /load via a request with just the pin like you have, then the frontend uses the token thereafter but can’t get the token in your case since /load doesn’t work. Let’s approach this from a different angle.
In SmartThings developer can you make the following edit to webCoRE smart app around line 934? Add two forward slashes to comment out the pistons: getChildApps() line as shown, then save and publish:
return [
name: location.name + ' \\ ' + (app.label ?: app.name),
instance: [
account: [id: hashId(hubUID ?: app.getAccountId(), updateCache)],
// pistons: getChildApps().findAll{ it.name == name }.sort{ it.label }.collect{ [ id: hashId(it.id, updateCache), 'name': it.label, 'meta': state[hashId(it.id, updateCache)] ] },
id: hashId(app.id, updateCache),
locationId: hashId(location.id, updateCache),
name: app.label ?: app.name,
uri: state.endpoint,
Try to refresh the dashboard again. Just trying to get the dashboard to load at this point, you’ll have a big sad face since it doesn’t know about your pistons after commenting out that line.
Cool cool cool. Before we kill off anything else that looks like it could error out let’s see where the error happens. Since I don’t know any better way to get more info from ST exceptions let’s just throw in some log messages:
In the webCoRE smart app replace the api_get_base_result code with the following:
private api_intf_dashboard_load() {
def result
debug 'A'
recoveryHandler()
debug 'B'
//install storage app
def storageApp = getStorageApp(true)
debug 'C'
//debug "Dashboard: Request received to initialize instance"
if (verifySecurityToken(params.token)) {
result = api_get_base_result(params.dev, true)
if (params.dashboard == "1") {
startDashboard()
} else {
stopDashboard()
} else {
debug 'D'
if (params.pin) {
debug 'E'
if (settings.PIN && (md5("pin:${settings.PIN}") == params.pin)) {
debug 'F'
result = api_get_base_result()
debug 'G'
result.instance.token = createSecurityToken()
debug 'H'
} else {
error "Dashboard: Authentication failed due to an invalid PIN"
if (!result) result = api_get_error_result("ERR_INVALID_TOKEN")
//for accuracy, use the time as close as possible to the render
result.now = now()
render contentType: "application/javascript;charset=utf-8", data: "${params.callback}(${groovy.json.JsonOutput.toJson(result)})"
small sample of the logging:
713686f8-6e0b-4230-af47-8d5401a376a3 4:40:26 PM: debug B
713686f8-6e0b-4230-af47-8d5401a376a3 4:40:26 PM: debug D
713686f8-6e0b-4230-af47-8d5401a376a3 4:40:26 PM: debug A
713686f8-6e0b-4230-af47-8d5401a376a3 4:40:26 PM: debug F
713686f8-6e0b-4230-af47-8d5401a376a3 4:40:26 PM: debug E
Perfect, no G means we’re on the right track. Let’s rip more out of the base result. It would be a good idea at this point to open the /load URL in a browser tab so that the dashboard doesn’t do anything whacky with all of this data missing.
private api_get_base_result(deviceVersion = 0, updateCache = false) {
def tz = location.getTimeZone()
def currentDeviceVersion = state.deviceVersion
def Boolean sendDevices = (deviceVersion != currentDeviceVersion)
def name = handle() + ' Piston'
def incidentThreshold = now() - 604800000
return [
instance: [
deviceVersion: currentDeviceVersion,
coreVersion: version(),
enabled: !settings.disabled,
settings: state.settings ?: [:],
lifx: state.lifx ?: [:],
// virtualDevices: virtualDevices(updateCache),
globalVars: listAvailableVariables(),
], //+ (sendDevices ? [contacts: listAvailableContacts(false, updateCache), devices: listAvailableDevices(false, updateCache)] : [:]),
// contactBookEnabled: location.getContactBookEnabled(),
// hubs: location.getHubs().collect{ [id: hashId(it.id, updateCache), name: it.name, firmware: hubUID ? 'unknown' : it.getFirmwareVersionString(), physical: it.getType().toString().contains('PHYSICAL'), powerSource: it.isBatteryInUse() ? 'battery' : 'mains' ]},
// incidents: hubUID ? [] : location.activeIncidents.collect{[date: it.date.time, title: it.getTitle(), message: it.getMessage(), args: it.getMessageArgs(), sourceType: it.getSourceType()]}.findAll{ it.date >= incidentThreshold },
id: hashId(location.id, updateCache),
// mode: hashId(location.getCurrentMode().id, updateCache),
// modes: location.getModes().collect{ [id: hashId(it.id, updateCache), name: it.name ]},
shm: hubUID ? 'off' : location.currentState("alarmSystemStatus")?.value,
temperatureScale: location.getTemperatureScale(),
timeZone: tz ? [
offset: tz.rawOffset
] : null,
zipCode: location.getZipCode(),
now: now(),
If it works you can remove the commented-out portions until it doesn’t work again. If it doesn’t work you can comment out more things…
There is an error in that somewhere I think - I have to run out for 30 min and will look into why when I get back unless anyone beats me to it:
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
script_app_metadata_f04c0aa5_611f_4b1e_8359_33fbc5d623a1: 966: expecting ‘]’, found ‘}’ @ line 966, column 1.
1 error
*I added an extra ] near the end and good for now but that’s likely not the right spot
